SOURCE: upright freezer--manual defrost
I would check that the door gasket makes good contact with the cabinet. If it does then I would check the temp inside the cabinet. If you have large buildups of ice on the evaporator coils then I would suggest defrosting the freezer and see if that makes a difference. Hope this helps.
SOURCE: Kenmore Upright Freezer Model 253.9239780 Temp alarm, Temp rising slowly
you have a refrigeration issue partner let her go 16 yrs. is good service you can replace it for 3 to 5 hundred the repair will be that IF you can find someone with the r-12. don't go for a top it off and go deal the food you lose is to expensive for that to be economical.
SOURCE: We have an upright Commercial Grade heavy duty
the suction noise is not something that will happen all the time.
check the current draw on the compressor and make sure it is in between 1.2 and 1.6 amps.also look at you evaporator coils and make sure there is no excessive frost build up.If there is ice build up then you need to defrost it check the heating element and defrost timer and make sure they are in proper working order.also check the evaporator fan and make sure it is working when the unit is in a cooling mode.
