Lost phone contact
SOURCE: CAN'T SAVE CONTACTS TO SIM ON SONY ERICSSON K800I
You will have to enter them manually or copy all of the contacts from your SE k800 phone memory to the simcard .
SOURCE: W960i with broken screen. How do I retrieve contacts?
using the bluetooth u can transfer the contacts it wil be easy
SOURCE: my sony ericsson c902 won't start up
I have had the same problem....did you find a solution in the end?
SOURCE: how do i copy contacts from my sony ericsson
Hi Barbara.
It's actually fairly simple to copy contacts on the x10.
Just access you phone dial pad via your menu
tap "Contacts" above the number pad
Press the bottom Left button (The real button at the bottom of the screen)
Should now pop a menu up with the option to copy contacts.
If not then tap the "More" option and it will be in there.
Now you have the option of copying them to the sim card or memory card.
Tap the relative option. :)
