If you want to Root an android device start here rootzwiki.com/
Each device is different so look up your particular device, model # and firmware #. Take precautions when trying to root your device and read up in your android forums about your device and the risks of rooting before you attempt this. Other than that good luck rooting!
---------------------------------------------------------------------- CREATE A RESTORE POINT BEFORE ANY OF THESE STEPS ----------------------------------------------------------------------
STEP 1: ====== Check if Plug and Play service is started.Check the settings of the same in the registry
STEP 2: ====== Advanced cleanboot (316434) and Hardware cleanboot (SOX051008700004)
STEP 3: ====== System restore (306084) If we know when the issue started, read the system restore point information for that day prior to trying the restore
STEP 4: ====== Look for the update KB905749 and try uninstalling it. Be sure to shut the system down and wait 10 seconds before restarting.
STEP 5: ====== Go to safe mode - check for bangs in hidden devices in System devices - Uninstall PnP BIOS Extension and any other device having a bang
If Administrators is listed, then remove Administrators. The default permissions for these keys are:
System : Full Control : This key and subkeys Everyone : Read Only : This key and subkeys
Change the permissions so that they apply to "This key and subkeys" and not just "This key only".
STEP 7: ====== We could try to register the following files regsvr32 devmgr.dll regsvr32 dmocx.dll If the files are missing, extract a copy from Windows XP CD-ROM or the ServicePackFiles folder
STEP 8: ====== Copy the following on a notepad.Save it as dev.reg.Double click on the same.Restart the computer.
Do the patterns of distortion change as you are twisting and bending the laptop body? If so, you're dealing with a logic board issue. Probably your GPU is not soldered properly anymore. Go to the Genius bar first, if they can't help you can try a self repair or send it to a third party place. There is a free Macbook Air Repair guide that will show you how to do it. iPad Repair
Did you choose a security question? (helps recover password)
OR Try This (taken from another forum)
"Try this Although there's no real way to recover a lost root password, you can change the root password even if you do not know the current one. You must have physical access to the machine in order to accomplish this task.
Click Restart at the login window While the computer is restarting, hold down "Command-S" until you see text scrolling through the window. This boots the computer into single user mode.
At the Localhost% prompt type: /sbin/mount -uw //sbin/SystemStarter
You will then see various services starting up.
When the Localhost% prompt reappears, type: passwd root
It will then ask you to type the new root password twice, so do so.
After entering the new password, type: reboot
At the login window, enter username root wih the new password.
Once you are connected, you can use the Multiple Users application (/Applications/Utilities) to change your normal user's password, or create a new user account."
My Gmini XS202s did this twice both time cause the battery went flat while moving files across (I should always charge device while connecting to PC)
First time I reformatted device as FAT32 using fdisk (Windows formatting tool should do same)
Then downloaded latest AOS and copied to root directory. [get AOS from http://www.archos.com/support/support_tech/updates.html?country=gb&lang=en]
second time I ran mkdosfs /media/disk (disk was mount point for gmini). This seemed to fix the device and I lost about 20 files. but better than reformat.
If the drive is mounted on your desktop single click on the drive icon. Press option 'i' keys to get the info about the drive.
The permissions will be listed in the window. As administrator you should be able to unlock the drive and change the permissions from here or if you have admin rights as the user you should be able to do the same.
If for some reason you are unable to do this you might have to reformat the drive. In this case copy the files you need on the drive off onto you mac and reformat the drive with the apple utility. You might have to change the permission on the files you take off the drive. You do the same thing as with the drive.
Once you are connected, you can use the Multiple Users application (/Applications/Utilities) to change your normal user's password, or create a new user account. Good Luck!!
