Brings up menu for sound on tv, won't change sound on the theatre system or will do both. All other buttons just bring up my menu on the tv not the reciever.
SOURCE: decode region on dvd player
Try 7385652500070000+INFO When You Put In A Movie Let Me Know If It Works.
SOURCE: We have a RTD259 RCA 5 disc home theatre system
Fist off, do you have Satelite TV or cable box? if so you need to run you audio wires from the audio out on those devices. If not from your TV should be audio out L&R to you audio input on your RTD259, now you may have a specific input for your TV, or you may not. If there is no specific inout for TV, there should be at least one AUX audio and video input open on your unit. Hope this helps, Cali
SOURCE: I have an RCA Home Theater System Model Number
Make sure that ALL ur cable r well conected! Sometimes just by moving cables it makes a difference.
SOURCE: No code for my RCA DVD HTS on my Philips Universal Remote.
does anyone have a fix for this problem, i have essentially the same problem, my remote is the phillips sru5107/27
1.
Hold down the
MENU button on the remote and VOLUME DOWN button on the TV it's self at the
same time for at least 4 seconds. The set won't say so, but the lock will be
unlocked
2.
Hold down the 0
(zero) button on the remote and the VOLUME DOWN button on the TV itself at the
unlocked
3.
Hold down the
MENU button on the front of the TV and the TV button on the remote at the same
time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU
button on the front of the TV at the same time for at least 4 seconds.
1. Hold down MENU on the remote and VOLUME DOWN on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
2. Hold down the 0 on the remote and the VOLUME DOWN buttons on the TV its self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds.
4. Hold down GO BACK on the remote and MENU on the front of the TV at the same time for at least 4 seconds.
5. Hold down EJECT on the front of the TV and the MENU button on the remote at the same time for at least 4 seconds.
