Got invalid toner message using after market cartridge. Tried taping over connector but got toner empty message. Tried moving chip from old cartridge and replacing in after market cartridge but still go toner empty message (presume because chip was from an empty toner)
SOLVED IT!
- PROBLEM: I'm using a refilled toner / NOT original Samsung (supplier: Peach, Switzerland)
- SOLUTION: 1. Remove the toner 2. Simply put a tape over the four metal contacts on the backside of the toner 3. Insert the toner
- It will now print, the printer says "low toner" & the LED status light is red - just ignore! It still work well....
- EXPLANATION: the chip (behind the four contacts) seems not be needed. I used a compatible 3rd party toner (Peach, Switzerland)
- Observation: The refilled toner worked well for the first 2-3 weeks, then suddenly I had this error message.
SOURCE: invalid toner
try to set your printers configurations fatory default 10. Maintenance > Of clear Of setting > Of all Of setting [OK]
In the service menu (TECH MODE):
MENU> Of data Of setup > Of clear of count > Of clear Of all CNT
SOURCE: toner empty after replacing new toner of samsung s...
press menu# 1934 then display tech mode
press left arrow key and enter twice
then its ok
to go normal display continue previous simulation.
SOURCE: Getting below error , even
you have to reset your toner visit
www.youtube.com samsung scx 4300 toner reset.
see video
SOURCE: Toner Exhausted Replace Toner" scx-4300
Hi
You need to raplce chip on cartridge
Pls vote me to keep me alive
