Frigidaire 30" Self-Cleaning Slide-In Electric Range - Black Logo
Alex Posted on Feb 28, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Burner replace how to remove glass top on fes366ebb
Bogdan Odwazny
Level 3:
  • Master 6,171 Answers
  • Posted on Mar 01, 2013
Bogdan Odwazny
Master
Level 3:
Answers
6171
Questions
8
Helped
1198715
Points
19890
Open on side screw and lift top support.unplug power.
1helpful
A pan stuck to the glass top on the front right burner when the burner was on. When I removed the pan it took a couple of chunks of glass with it. Now there are two chuncks of glass missing from the...
Sorry to read about your problem, I hope this helps you out.
You are not going to like this, and you did not give the model number of your unit. But glass replacement tops, will range from $600.00 to $800.00 just for the glass top. and their is not a way to make repairs, because it is a special glass.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
HOW DO YOU REPLACE BURNER SWITCHES? REMOVE ENTIRE UNIT FROM THE COUNTER TOP, OR IS THERE A WAY TO JUST REMOVE GLASS TOP TO ACCESS SWITCHES?
Take off the switch nobs and center grate, then carefuly lift the glass up/ start on one edge first. Have a towel or pillow to rest the glass once off it is around 250$ to replace glass!
2helpful
How do I repair A knob that is broken off at the stem of my ge profile flat top stove?
You cannot repair this switch, you will have to replace it.
You will need to remove the cook-top and remove the glass top to access the switches. There will be a series of screws around the underside of the lip of the glass top that attach it to the burner box. Remove all of the remaining knobs and lift the glass straight off the box.
I would get your model number and order the replacement switch before starting the process.
good luck!
The glass top on one burner has discolored under the glass as if it is burned under the glass. nothing will clean it. what do I do to get the black out
if under glass it will have to be removed to clean/ it might not clean. . the replacement is only other ans . mm
1helpful
How do you replace large element on dual burner? How do I remove the glass top?
the duel element is just that
a duel element, when you order the replacement it will come with both burners in the circle
the top comes up after you remove the srews under the lip above the top of the door
unplug this before youy toch anything
then write down where each wire connects on the burner and reconnect them the same way on the new burner padles
3helpful
GE EVOLUTION Glass top. The hot surface(Glass top)
Individual burners, located directly under the cooktop glass, contain a temp sensor which lights up the hot surface lamp when they sense a hot condition. If the light stays on after all burners are cool, one of the sensors has shorted out. The sensors are an integral part of the burner, so the offending burner must be replaced to solve your constant on hot light.
I have a GE profile Glass top M#JSP47COF4CC That is cracked but can't figure out haw to remove. Have already removed 4 screws under control panel still won't budge
To remove the top on this range, remove burner knobs and face plate, then remove 2 screws from control panel one at each end. Fold panel down out of the way, remove 5 screws accross front of control panel and release 2 quick connect plugs for burners, then lift to remove glass top. Flip over remove 2 screws and clips from each burner and the indicator light assembly just pops out. Transfer this to new top and reverse your steps for removal.
7helpful
Kenmore glass top range left front large burner out
check the burner socket, it is likely that contact is being lost where the burner connects to the hardwired portion of the system (the socket). It is not unusual for the socket to "burn up" when there is a poor connection to the burner resulting in the burner being replaced and the new burner not working or working intermittently.
Please take the time to rate this solution
1helpful
REPLACE CRACKED GLASS COOK TOP
First of all, if the cook-top broke as a result of a manufacturer defect, the repairs should be covered under the manufacturer's warranty. In this case, the repairs would be done at no cost to you. If, however, the glass top was broken as a result of the consumer, the repair will not be covered (even if it is still under warranty). If this is the case, it does not require an engineer to replace a glass cook-top. It can be time consuming, though. If you are somewhat savvy with fixing things, it can be accomplished by the average do-it-yourselfer. The following link explains how to replace most glass cooktops:
http://www.fixya.com/support/r391448-replacing_glass_cook_top
The tedious part of replacing the cook-top is carefully removing and handling each burner element. These are usually ceramic and are very fragile. You must be handled with care. If there is no common disconnect, you also will be required to unplug each burner assembly one at a time and label the wires. A digital camera can come in very handy for this as well. The easiest way to do this is to remove the old shattered cook-top, first and lay it side by side with the new one. Remove and install one burner element at a time.
If you wish to pursue this and require additional assistance, please let me know before you rate the solution. I hope this helps you.
Top Frigidaire Kitchen Ranges Experts
Paul Carew
ZJ Limited
ZJ Limited
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
