When I start to sew, the thread from the bobbin starts to gather under neat the cloth and then the thread breaks. I already fix the tension from both threads and the problem still continues. Can anybody please help ?
Try these suggestions
1. Change the needle--use a needle that's for the fabric being sewed
2. Rethread the machine--top --make sure to use every thread guide
3. try a different bobbin--make sure bobbin is inserted correctly into the bobbin case, & make sure the bobbin is turned the correct way in the bobbin case
4. make sure the thread has not come off the thread take up lever
5. Clean under the needle plate & in the bobbin area for lint or threads
SOURCE: Bobbin thread breaks
Make sure your bobbin thread is turning clockwise as it sits in the bobbin case. There is a screw on the outside of the bobbin case you can turn with your thumb slightly to adjust tension. If you dangle the case from the thread and give it a light ****, it should move down slightly when doing so-an indicator of good bobbin tension.
SOURCE: thread shreds with Pfaff
I have the book on that machine as well and I have had that problem. Here is what had happened to me: I was soooooo tired of that shreading thing that I took a flashlight and aimed it up the nose of the machine by the lightbulb and fould there to be a nice little rats nest wrapped around the take-up lever and the needle bar. I spent the next three hours getting to that nest with the skinniest and longest tools I could find. Oh it is was fun!
SOURCE: Bottom (bobbin thread) makes loops
I don't have the same brand as yours, but on my machine there is a little screw on the bobbin case that you tighten to increase the bobbin tension. If you've got one, turn it 1/8 to 1/4 turn at a time.
SOURCE: My Pfaff sewing machine has started to loop the
If the thread is looping underneath, you're top tension may be too loose or the thread may not be in the take-up lever. If it's looping on top, double check that the thread is in the bobbin tension or that the bobbin tension isn't too loose.
