Proscan 32LA30Q Television Logo
Posted on Feb 28, 2013
Need to program a sudden link cable remote
Unable to program the sudden link cable remote to any codes in booklet
Suddenlink Shannon
Level 1:
New Friend:
  • Contributor 20 Answers
  • Posted on Mar 02, 2013
Suddenlink Shannon
Contributor
Level 1:
New Friend:
Answers
20
Questions
0
Helped
5185
Points
20
Hi sweet_tweet- My name is Shannon and I am with Suddenlink. You can visit our self- help site here to access remote control codes: http://help.suddenlink.com/Television/Pages/RemoteControls.aspx. Thanks!
Need a remote code for fluid tv using rogers remote
Hi MiMi I attempted to search for the Code for your TV under several of the Rogers remotes and was unable to find one. You can do a general search for a code on any of them following some minor instructions. Navigate to link , choose the remote that looks like yours and then to the left will be choice to search all possible codes. Hope this helps. Good luck Rogers Cable Remote Support
Unable to program remote
Have you tried the "KMC" code (should be 219). KMC is Konica Minolta who used to make Konka TVs. Here is the link to the programming instructions and all the codes if you need; http://optimum.custhelp.com/cgi-bin/optimum.cfg/php/enduser/std_adp.php?p_faqid=1420 If that code doesn't work, then apparently philips codes may work for your model (164, 005, 038, 093, 127, 070, 003, 004, 059, 236, 238, 243, 247, 199) (sorry you have to work through them one at a time). Hope the KMC one works :)
1helpful
2answers
Please tell me how to program a Philips SRU3004 TV remote along with the code. Thank you!
Here is a link to a PDF of the manual:
http://download.p4c.philips.com/files/s/sru3004_27/sru3004_27_dfu_eng.pdf
Page 8 has step by step instructions for programing codes.
This is a link to a page on the Phillips site with a code search form:
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?scy=GB&slg=ENG&sct=URC_REPLACEMENT_SU&cat=REMOTE_CONTROLS_CA&grp=ACCESSORIES_GR&session=20110902175210_207.224.241.131&ctn=SRU3004/27&mid=Link_RCCodeFinder&hlt=Link_RCCodeFinder
WHATS THE CODE FOR RCA TV ..I HAVE A ONE FOR ALL UNIVERSAL REMOTE NEED THE CODES TO PROGRAM MY RCA TV
You received a list of ALL Codes with your universal.
I got this off the internet. But I do not know what type of universal you bought. You didn't mention it.
Good Luck.
Here is the link if you need it. :0)
http://www.google.com/search?q=universal+code+for+rca+tv&rls=com.microsoft:en-us:IE-SearchBox&ie=UTF-8&oe=UTF-8&sourceid=ie7&rlz=1I7GGLL_en
rca
1helpful
Need to program a new remote for RCA TV
Programming Your Universal Remote.
The remote may already be set up to operate your brand of TV, VCR, or Cable Box. It is pre-programmed with following codes:
  • TV-000
  • VCR-000
  • Cable Box-000
  • AUX is programmed with VCR code 037
For brands that require programming, there are two ways to program: Using Code Lists or Code Search. Use Code Search if the code lists are not available or if the codes from the lists do not operate a device.
Programming a Device using Code Search:
  1. Manually turn ON your device (TV, VCR, Cable Box)
  2. Press and "HOLD" CODE SEARCH
  3. Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once.
  4. Release CODE SEARCH.
  5. Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second).
  6. Once the device turns off, press and release ENTER.
  7. With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Programming a device using the Code Lists:
  1. Find codes for each device and brand below.
  2. Press and "HOLD" CODE SEARCH.
  3. Press and release the TV, VCR or Cable button you want to set up. If programming AUX for a device, press and release AUX first and then the device to be programmed (TV, VCR or Cable). When the selected device button flashes proceed to the next step.
  4. Enter the three digit code from the TV, VCR or Cable Box code lists.
  5. Release CODE SEARCH.
  6. With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using another code number from the lists.
For more info, copy and paste this link in your address bar so you can get codes for you remote:
http://www.thompsontv.com/rcarc.html
8helpful
5answers
How to program a jumbo touch screen universal remote control
I just found my booklet for the Jumbo Touch Screen Remote Control
item no: NV-00268
if this is your remote; list the device and model name for the codes you need and i'll do my best to help
2answers
How do we code a remote for a magnvox 27
Is it Comcast? With our cable box came an instruction booklet with codes for different brands. We tried two or three before finding the right one.
I can't find the instruction booklet we had, but you might find one on your cable company's website.
Need remote codes ??
Hey Howeiw, I know that posting links doesn't help majorly, but I was unable to Find an "EV-1000 10.4 inch LCD Television" The closest I could find was just an EV-1000B. But that is not the same model. If you take some time when you have a chance, and visit http://www.xdiv.com/remotes/, That site has ALL of the Remote Codes for all Cable Systems.
Hope this Helps. - Evolution
Codes
I have the same problem with the Cox Cable remote attempting to make it recognize my Emerson model LC320EM8 HD TV. The booklet with the remote shows 20+ codes for Emerson TVs and I tried them all, I then tried the channel up/down search, to no avail. Is there a code for this TV, or do I have to buy another Radio Shack universal remote like I had to do with my other TV home theater system?
Top Proscan Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
