Hello 2cats - First, is the drain pump making a humming noise? If so, the unit could possibly have a restriction in the drain line. Try setting the cycle to spin only and verify if water pumps out. Other possibilities could be a faulty door lock, timer, pump, or control board not communicating correctly. In this case I would contact a professional to move forward accurately to properly diagnose and repair the washer.
Same problem with the beeping.
I press and hold the pause/cancel button for about 5 seconds and it stops.
SOURCE: frigidaire affinity front load washer doesn't start
mabye there is something keepin the door open, thats usually why most washers dont start
SOURCE: Constant beeping
I have an ATF8000 that did the same thing, unfortunately when this happens the entire control board must be replaced. I bought it for about $130 from a local appliance repair shop who then installed it for about $50. In all with tax it was near $200 repair.
SOURCE: I have a Frigidaire washer model FTF2140ESO that
I've had this happen before. Try unplugging it and leaving it unplugged for about five minutes. Plug in and try again.
Leslie
SOURCE: my front load washer keeps beeping even when there
Beeping is pretty vague, but here it goes. Read the very broad answer. Your answer will be in it. I hope this helps.
LOOK HERE
SOURCE: my washer started beeping and
the flashing is an error code, count the number of blinks. also turn the power off. wake up the washer by touching any one bottom. then press cancel an pause buttoms at same time. it will display an error code. write that down an repost it
Thanks for your inquiry, Barbara Williams!
I understand that the lights on your Frigidaire washer are blinking and beeping. It sounds like your washer is providing a set of error codes. Your control panel may need to be replaced. I would recommend contacting a professional technician for proper diagnosis to be completed to avoid any unnecessary part purchases. Hope this is helpful. -Matt
