Washing Machines Logo
Anonymous Posted on Feb 19, 2009
Spin cycle shuts down when tub wobbles on GE washer
With nothing in the washer it goes through a compete cycle with no problems. When clothes are put in, agitation is fine. When the spin cycle starts, the tub will rotate two or three revolutions and wobble quite a bit and then shut down. It will start spinning again and then wobble and shut down again. With the front panel off I can hold the tub steady and after six or seven revolutions let go of it and it will spin fine. All hangers and retaining straps are in place and in good shape.
Model # WLDSR416FOWC Serial# DL165926G
Thanks for any help you can offer.
Gary
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Feb 24, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
386
Points
The tub continues to go off balance in spin cycle. Starts out smooth then starts to wobble terribly til the UL shows and shuts down. Support rods are good
There is a little device inside the washer that allows the agitator to spin independent of the drum. If this gets stuck, the washer will try to spin the whole drum instead of just the agitator. This will cause the washer to think the load is too large or out of balance, causing the error code. On some Whirlpools this device is just a washer.
2helpful
Clothes are to wet after spin cycle
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these: Motor coupler Spin cycle Siphoning Water-inlet valve Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning: If it's spinning when you lift the lid, the coupler is fine. If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely. Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component. Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician. Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess. Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
A load goes through a complete cycle but the clothes are still wet. i can see the drum turning during spin but in my opinion not fast enough. what could be the problem?
2helpful
Towels come out soaking wet, too wet to put in dryer. When placed back in dryer, noticed the spin cyle runs slowly, never spinning fast. The drum itself isn't solid, but oscillates when spinning.
2answers
2answers
Washert not draining
If your washer spins but doesn't pump the water out, the drain line might be clogged.  In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump. You already have replaced the pump motor and still no operation,  so check the power voltage to the pump during the drain cycle.   Verify the problem is not pump related as much as power to the pump being the problem.
2answers
Clothes still wet at end of spin cycle
i would check your belt.the added stress of a full tub longer with water may have done it in.part#wh1x2026 God bless,tom
1helpful
GE top load washer does not agitate or spin.
sounds like a bad lid switch how old is it?
GE Top Load Washer WLSR2000G3WW~smells like burning and wont drain
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Top GE Washing Machines Experts
Virgil Watts
Steve Sweetleaf
Steve Sweetleaf
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
