Question about Sony DDS SDT-9000 DAT Tape Drive
I have A Sony DDS drive unit SDT-S9000 and I can not get it to work with windows Xp. This is because I have no driver for it can anybody help please. Thanks
    Problem Solver:
  • 6 Answers
SONY SDT-9000 is needn't driver in Windows XP. or you can download driver in http://sony.storagesupport.com/product/17#drivers
Posted on Mar 06, 2009
SOURCE:
Ive just bought an old sony dat drive SDT-5000 and want to use the external housing frome one I already have. Does anyone know how to set the jumpers? I can supply an image of this if it helps
supply an image (and would be great if you could supply image from old broken one and new one)
I'm a bit confused though: if you have an internal working sdt-5000 that you want to put into an external broken sdt-5000, it should be as simple as getting the enclosure open, then swapping the internal drives; i.e. external enclosures usually still use the same spec internal drive so it would just be an ide or scsi connector cable.
I’m happy to assist further over the phone at https://www.6ya.com/expert/shunter_ccf54e0913bd0501
Jul 12, 2016 | Sony DDS SDT-5000 DAT Tape Drive
Power windows dont work
There is a circuit breaker for power windows .
Power Window System Components
The power window system consists of the following components:
Driver Door Switch (DDS)
Passenger Door Switch (PDS)
Body Control Module (BCM)
Rear door power window switches
Power window motors in each of the doors
PWR WDO Circuit Breaker
Power Window System Controls
The power window system will operate anytime the Retained Accessory Power (RAP) system is active or when the ignition switch is in the ACCY or ON position.
The driver master control switches are integrated into the DDS. When a power window switch is activated in the up or down positions the DDS supplies power and ground to the window motor control circuits to drive the window motor in the required direction. Prior to activating a power window motor the DDS will supply the control circuit with a low current bias voltage in order to determine that a short to ground condition does not exist and during window motor operation the DDS continues to monitor the motor current to verify proper window motor operation.
The DDS controls the passenger window by a serial message to the PDS. When a power window switch is activated in the up or down positions the PDS supplies power and ground to the window motor control circuits to drive the window motor in the required direction. Prior to activating a power window motor the PDS will supply the control circuit with a low current bias voltage in order to determine that a short to ground condition does not exist, and during window motor operation the PDS continues to monitor the motor current to verify proper window motor operation. (Scan tool support is available for this system
Check this circuit breaker
RETAINED ACCSRY PRW BRKR 30 amp. located in the left instrument panel fuse box . if the breaker is good check power B+ at the drivers door switch . connector 1 terminal b yellow wire . Sometimes the wires inside the rubber boot coming from body to door break .
Oct 29, 2015 | 2005 Chevrolet Impala
Tar /dev/st0 can't write: error
Sounds like your tape drive or possibly the tape you are using is faulty.
check the following:
#1 - use a different tape
#2 - check that the read-only is not enabled on the tape(s)
#3 - run diagnostics on the drive (if it's come with software for diagnostics).
#4 - return it to the supplier to test and replace if under warranty.
Apr 04, 2010 | Sony DDS SDT-S9000 DAT Tape Drive
DDS-5 not compatible with windows 2008
I am pretty sure that the driver should be compatible with win08.
If you are using backup exec then try switching to use symantec drivers for your tape drive (setting withing BUEX)
If it is just the tape that cant be read or identified and was backed up using windows backup then try restoring the backup on a 2003 server and then copying the data across the network.
May 10, 2009 | HP 364446-001 Storageworks DAT 72x6 DDS-5...
XP Drivers for Sony Vaio VGN-fw230j/b
It's probably not supported Sony.
You can try and downgrade but you might lose some functionality. I downgraded my Vista Gateway laptop to XP but had to spend a lot of time tracking down drivers that would work correctly.
You won't be able to just pop in an XP cd and install. You'll have to jump through a few hoops.
Here's the biggest hoop and guide here:
http://maxeasyguide.blogspot.com/2008/04/preparations-for-winxp-installation-cd.html
Since you have a newer laptop your hard drive uses sata drivers which the XP cd doesn't have built-in.
Let me know if you get stuck or have anymore questions.
Feb 24, 2009 | Sony VAIO VGN-FW230J/B Notebook
Unlocked tapes recognized as locked
this is probably due to a stuck microswitch in the tape drive unit as the locked tag presses a microswitch when loaded it is possibly these microswitches that are failing, as one of the switches detects if a tape is loaded and the other detects is a tape is locked, so problems with these switches would mean that it cannot detect if the tape is loaded properly.
Sep 30, 2008 | Sony DDS SDT-D11000/ME DAT Tape Drive
Open Questions:
Malwarebytes Antivirus Support*O#1=855=536=5666 pHoNe nUMber ']F$ Malwarebytes Antivirus Support $1/855/536/5666 $ pHoNe tMICo resolve all Malwarebytes Antivirus products. Malwarebytes Antivirus is an American multinational company which was founded by Michael Malwarebytes Antivirus using its company headquarters in Round Rock, United States of America.Contact Malwarebytes Antivirus for Setup & Installation Malwarebytes Antivirus Setup Support & Installation Malwarebytes Antivirus Helpline number Connect is a utility carrier that lets in you to print and scan from anywhere. The Wi Fi characteristic in it makes it very on hand and easy to use. So, when you have in the end determined to head for Malwarebytes Antivirus Connect, Malwarebytes Antivirus Helpline Phone Number you'll be searching out Malwarebytes Antivirus Connect setup as well. So, here we're with all cthe setup process and for your to Malwarebytes Antivirus Connect. Get Malwarebytes Antivirus Setup Instant Support Malwarebytes Antivirus Customer Service Phone Number Usually, the setup Customernique takes a number of time. One Customernique if accomplished incorrect, they could break the entire manner and you may should do it again. That's why here you may Malwarebytes Antivirus locate the approaches simplified to help you even if you aren't Customer savvy. Let us undergo the method Of Malwarebytes Antivirus Connect setup for Windows and for Mac Out. So, Outright here we go vikki
Oct 17, 2019 | Carrier Computers & Internet
See all Sony DDS SDT-9000 DAT Tape Drive Questions
Sony DDS SDT-9000 DAT Tape Drive Logo
444 people viewed this question
Top Sony Computers & Internet Experts
Ekse
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
