It started 1 st. Message no tonner 2nd No pick paper ! In 2 days. I did turn upside down the unit to see and have access. I checked to see if anything is clogged or stucked Suddenly after the 2 I fixed - the printing was bad as described. I changed the cartridge - also with an original. The scanning works. Before - nothing to print - the copy was blanc. Thanks DT
SOURCE: Only printing top few lines
check the print driver in control panel...... if the correct driver for the printer is not installed, or corrupted, it can send invalid instructions to the printer, but let me check....... ahah! found it..... it's a carriage stall (not the horse kind :-') ) but the print head carriage is jamming for some reason, either there is some grit on the carriage bar, or a missing tooth in the drive belt, or the timing strip is dirty..... the easiest to fix yourself would be to clean the timing strip. the timing strip is a clear plastic tape usually behind or below the carriage bar. it looks like it has a grey horizontal stripe across it (actually it is many tiny vertical black stripes that provide the printer with motion and dot timing information). carefully with a window cleaner soaked paper towel, and without too much pressure (that would unhook one of the ends of the strip)wipe the strip clean on both front and back. also if the printer happens to be in an unlocked condition (you can do this by removing power during the head positioning cycle), try moving the printhead at a moderate speed back and forth along the carriage bar and see if there's anywhere where it binds up or you feel more than normal resistance, the printer needs repair, but at least you can tell the technician where to start looking....
SOURCE: Black lines on scanned copies
Try this. Lift the lid to expose the top glass. To the left of the main glass panel, you will see a narrow glass strip. Clean this strip using a soft cloth or sponge moistened with a nonabrasive glass cleaner, then dry it off with a dry chaois cloth or cellulose sponge. A.
SOURCE: Duplex printing: 2nd page is upside down.
START PRINTERS & FAXES PRINTING PREFERANCES choose both the options - print on both sides - flip the page option apply ok close the printing preferances box try printing
SOURCE: The print cartridge cradle cannot move.
"The print cartridge cradle cannot move."
I fixed this problem by disconnecting the power cord from the power-strip and connecting it directly into the wall. My printer was not getting enough voltage from the power-strip. I hope this helps.
SOURCE: My HP Officejet 5610 All-in-One won't copy or scan any document
Fiend your solution direct from hp. Here is your solution...
http://www.hp.com/printer/prob676ijt65/solution
a7
