SOURCE: Check engine light 05 taurus
From what I understand even a "qualified" Ford mechanic has problems locating this and if you look at a pre-2000 Haynes or Chilton manual it shows it being in a completely different location but to answer your question from what I understand (never changed one myself) it's on the passenger side, under the dash and should be by the radio. Should be held on by one or two screws. Also easy to get to if the radio is removed.
SOURCE: car stalls at traffic lights and stop signs
it could also be the idle control valve not working properly, it could be carboned up, remove and clean with a cloth then replace and try car
SOURCE: my anti lock brake and traction control light came
Could have a ABS wheel speed sensor going bad, once this happens will disable the ABS and the trac control. Have it scanned and find out which sensor is bad. Small possibility of ABS module failure, but not as likely.
