Question about Broderbund Computers & Internet
I get a warning box that says, "PMW - the text box is full"
When I cut and paste text from another document into the Print shop text box, it comes up with a warning box that says, "PMW - the text box is full". Then it says there was an error and print shop has to close down. It then shuts down.
6ya staff
SOURCE:
Anonymous
SOURCE: only printing partial page
hp psc 1315 printer dead due to lighting send me circuit drawnig
Posted on Dec 15, 2007
QBPOSScott
Scott Fair
  • 237 Answers
SOURCE: Printing
There can be multiple causes for this one.
You may have data damage, with broken transactions.
You may have List damage, which a verify will not pick up.
Your list of accounts\ customer names, may actually be so complex (jobs plays into this also) that you are crashing the computers resources-running it out of memory. This is especially true of older computers. This data file ay have been in operation for years, and become very large ( do control + 1 to see the file size).
Also, it was noted in some of the older versions, that Qb could have problems printing a large number of statements. In those cases, it was recommended that you try 100, then 200, and so on until you found the breaking point (which, if memmory serves was around 400, give ot take).
Under file, utilities, there will be a verify data option ( with a large file on an older system , this can take a LONG time, to the point you think it has quit, if the Hard disk light is flashing, it is still working on it, It may take hours, or in some cases, more than a day to complete.
Another issue that may affect the outcome is the number of UNUSED accounts. They may be empty, but the program still has to crawl through them. Later versions have a capability called a Portable Company File, which removes unused accounts, names and such, and can speed the efficiency, this was not present in your version.
Posted on Sep 15, 2008
leroyal
Leroy Elliott
  • 2120 Answers
SOURCE: Horizontal white lines through the text
Your ink cartridge (s) is dried up, even some new ones are dried up, even tho' they're sealed.
Some self-tests don't use black.
Posted on Sep 21, 2008
freetek
Steve Allison
  • 5569 Answers
SOURCE: error 404 comes up when I try to install my print shop 20
That message implies that the program has tried to reach an on line website, perhaps to register, but has failed because your connection was not active at that time. Try reinstalling it while connected.
Posted on Jan 07, 2009
Anonymous
  • 18 Answers
SOURCE: My printer won't print black ink even though the cartridge is full
try to clean the nossles with software from the manafactures website
Posted on May 06, 2009
WILL ONLY PRINT EVERY ALTERNATE LINE OF TEXT & TEXT BOX BORDERS
Doesn't sound like your printer hardware. Try printing something other than your text document. If the page comes out clean/perfect then it means your printer is having a problem understanding your text document via print program translation. Otherwise try converting your text to pdf and print a sample page, if it works then again problem with software/printer translation.
Nov 24, 2013 | Epson Stylus CX3810 All-In-One InkJet...
Cut and paste
Learning how to cut and paste can make your life on the computer much easier.
It saves time and is more accurate that retyping the information, particularly if you do it several times.
If you know how to highlight words on your computer, you can easily copy sections of text and paste them somewhere else.
Open a text document or an email that contains some type.
Click at the end of the block of text you located in Step 1 and drag with your mouse back to the beginning of the text to highlight the entire block of type you wish to copy.
Release the mouse. The selected area should be highlighted in a color, usually blue.
Right-click the mouse on the highlighted text and a drop-down menu appears.
Select "Cut" to copy the highlighted text and remove it from its original position.
Select "Copy" to copy the highlighted text and leave it in its original position.
Paste the text you copied.
Right-click in an editable text box and select "Paste" from the drop-down menu.
The text appears in its new location.
Alternatively, highlight the text and hold down the "Ctrl" key on your keyboard while you press the "X" key to cut the text or the "C" key to copy the text.
These keyboard shortcuts copy the text that is highlighted.
To paste it, click in a text box and use the "Ctrl" and "V" shortcut to paste.
Cut and Paste Techniques in Microsoft Word
http://www.homeandlearn.co.uk/mw/s3p2.html
Aug 25, 2013 | Computers & Internet
I want to cut and paste some parts of and article and put it into one document. How do I find the cut and paste buttons to do this?
General copy + paste shortcuts are
Ctrl + C for copy Ctrl + V for paste Ctr + X for cut
In your source document, highlight the piece of text you want to copy -- click and drag over the text -- hit Ctrl + C, or Edit -> Copy
Move to your destination document, where you wish to paste your quotations, and hit Ctrl + V, or Edit -> Paste
May 06, 2011 | Acer Aspire One Netbook 8.9" Notebook
I now have Works, rather than Word on my computer. I also now have Hotmail rather than OutLook Express . . . which both are a heartache to me. One reason is that I used to be able to highlight and drag...
Highlighting is similar to cutting the portion of text to be pasted at an alternative area on the page displayed. Right clicking on the portion of text should generate the features list to cut text as copies to be later pasted onto another area. A situation where text cutting or copying is achievable though does to allow to paste on the same area has alternate capabilities of achieving success. Cut the email text required paste to an opened empty Microsoft word document to edit into desired specifications. Usually, the email has least capacity to allow several functions all at once. A cut text may be possible least allowing pasting since the program is still in enable mode until uncut is achieved. For example, cut the portion required to paste on clipboards or Microsoft word document. Once the text that was cut is pasted elsewhere, the function of cut has been disabled. Returning to the email area requiring pasting should be achievable with an open display area requesting a past feature. In which instance, the open Microsoft document contains the copy that would provide display to the email section requesting displays.
Jan 26, 2011 | Computers & Internet
How do you cut and paste from one document to another
The Microsoft Office allows you to copy text andgraphical items from Office documents or other programs and paste them intoanother Office document. For example, you can copy text from an e-mail message,data from a workbook or datasheet, and a graphic from a presentation and thenpaste them all into a document. The simplest way to copy data from one documentto another is as under. However, there are numerous options/ possibilities. Step-1 Select / Highlight the text you wish to copy toother document. Step-2 Click the copy button (Or press Ctrl +C) Step-3 Go to the document where you want to paste thecopied data and press paste button (or press Ctrl+V) Let me know if any further clarification/ assistance isrequired. Hope this helps! Good Luck! CreativeTECH
Jan 12, 2011 | Microsoft Office Professional 2007 Full...
I want short cuts in ms word
You can use this
Ctrl + A Select all contents of the page. Ctrl + B Bold highlighted selection. Ctrl + C Copy selected text. Ctrl + E Aligns the line or selected text to the center of the screen. Ctrl + F Open find box. Ctrl + I Italic highlighted selection. Ctrl + J Aligns the selected text or line to justify the screen. Ctrl + K Insert link. Ctrl + L Aligns the line or selected text to the left of the screen.
Ctrl + M Indent the paragraph. Ctrl + P Open the print window. Ctrl + R Aligns the line or selected text to the right of the screen. Ctrl + T Create a hanging indent. Ctrl + U Underline highlighted selection. Ctrl + V Paste. Ctrl + X Cut selected text. Ctrl + Y Redo the last action performed. Ctrl + Z Undo last action. Ctrl + Shift + F Change the font. Ctrl + Shift + > Increase selected font +1pts up to 12pt and then increases font +2pts. Ctrl + ] Increase selected font +1pts. Ctrl + Shift + < Decrease selected font -1pts if 12pt or lower, if above 12 decreases font by +2pt. Ctrl + [ Decrease selected font -1pts. Ctrl + Shift + * View or hide non printing characters. Ctrl + Moves one word to the left. Ctrl + Moves one word to the right. Ctrl + Moves to the beginning of the line or paragraph. Ctrl + Moves to the end of the paragraph. Ctrl + Del Deletes word to right of cursor. Ctrl + Backspace Deletes word to left of cursor. Ctrl + End Moves the cursor to the end of the document. Ctrl + Home Moves the cursor to the beginning of the document. Ctrl + Spacebar Reset highlighted text to the default font. Ctrl + 1 Single-space lines. Ctrl + 2 Double-space lines. Ctrl + 5 1.5-line spacing. Ctrl + Alt + 1 Changes text to heading 1. Ctrl + Alt + 2 Changes text to heading 2. Ctrl + Alt + 3 Changes text to heading 3. Ctrl + F1 Open the Task Pane. F1 Open Help. Alt + Ctrl + F2 Open new document. Ctrl + F2 Display the print preview. Shift + F3 Change the text in Microsoft Word from upper to lower case or a capital letter at the beginning of every word. Shift + Insert Paste. F4 Repeat the last action performed (Word 2000+) F5 Open the find, replace, and go to window in Microsoft Word. Ctrl + Shift + F6 Opens to another open Microsoft Word document. F7 Spell and grammar check selected text and/or document. Shift + F7 Runs a Thesaurus check on the word highlighted. F12 Save as. Shift + F12 Save. Ctrl + Shift + F12 Prints the document. Alt + Shift + D Insert the current date. Alt + Shift + T Insert the current time.
Oct 11, 2010 | G7 Productivity Systems VersaCheck For MS...
Cannot download Document Imaging onto Microsoft
Okay go to google translator and copy and paste the code into the text box and translate it into english
Jan 20, 2010 | Microsoft Office Professional 2007 Full...
I have the Epson Stylus CX7800 and I'm out of magenta ink, but have full black. Now, I just want to print black text, but it won't let me. Is there any way to get past this? It's extremely important that I...
Yeah. Go into the print settings. Which should open when you begin to print a document. there is a setting to print in greyscale. Also, make sure that the printer options are set to plain paper and set for documents
Dec 08, 2008 | Epson Stylus CX7800 All-In-One InkJet...
Printing pdfs with highlighted text/shaded areas
That just means that you don't have a postscript enabled printer, or possibly you're using a black and white only printer. You might be able to print highlighted items normally on other printers, but will have to remove the highlighting to see the text on the one that you have. Alternatively, if removing the highlights isn't possible, you might try selecting all the text and then pasting that into a new document in a word processor or another similar program. If you do have a color printer, and need to print what you're seeing, you can arrange the document so that it is centered on your screen and then press: "Alt + Print Screen" at the same time. You can then open MS Paint or a similar photo editing program and paste ("Ctrl + V") the screen capture into the program.
Let us know if you need further help.
Hope this will FixYa!!!
Oct 30, 2008 | Adobe Acrobat 7.0 for PC
Dreamweaver CS3
Import Microsoft Office documents (Windows only) You can insert the full contents of a Microsoft Word or Excel document in a new or existing web page. When you import a Word or Excel document, Dreamweaver receives the converted HTML and inserts it into your web page. The file’s size, after Dreamweaver receives the converted HTML, must be less than 300K.
Instead of importing the entire contents of a file, you can also paste portions of a Word document and preserve the formatting.
Note: If you use Microsoft Office 97, you cannot import the contents of a Word or Excel document; you must insert a link to the document.
  1. Open the web page into which you want to insert the Word or Excel document.
  2. In Design view, do one of the following to select the file:
    • Drag the file from its current location to the page where you want the content to appear.
    • Select File > Import > Word Document or File > Import > Excel Document.
  3. In the Insert Document dialog box, browse to the file you want to add, select any of the formatting options from the Formatting pop-up menu at the bottom of the dialog box, and then click Open. Text Only Inserts unformatted text. If the original text is formatted, all formatting will be removed.
    Text With Structure Inserts text that retains structure, but does not retain basic formatting. For example, you can paste text and retain the structure of paragraphs, lists, and tables, without retaining bold, italics, and other formatting.
    Text With Structure Plus Basic Formatting Inserts both structured and simple HTML-formatted text (e.g., paragraphs and tables, as well as text formatted with the b, i, u, strong, em, hr, abbr, or acronym tag).
    Text With Structure Plus Full Formatting Inserts text that retains all structure, HTML formatting, and CSS styles.
    Clean Up Word Paragraph Spacing Eliminates extra space between paragraphs when you paste your text if you selected Text With Structure or Basic Formatting. The contents of the Word or Excel document appear in your page.
Source: Dreamweaver CS3 Help
Feb 06, 2008 | Adobe Photoshop 7.0 for PC
Computers & Internet Logo
47 people viewed this question
Top Broderbund Computers & Internet Experts
Peter Dragonetti
Norman Worley
Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
