Its very complicated problem that ive been trying to fix for the last 2 months ... when i turn the key all the way in the ignition the car start and drives normally but everything inside the car does not function , BUT when i turn the key a quick turn the car start and runs great and everything inside functions normally, the check engine light is on throwing the code " serial communication link "
The engine/powertrain control module (ECM/PCM)
The electronic brake control module (EBCM)
The HVAC control module
The radio
The dash integration module (DIM)
The rear integration module (RIM)
SP303
The inflatable restraint sensing and diagnostic module (SDM
All These modules share information on the class 2 serial data bus any one of these modules could have a lose or bad ground causing these problems !
Scan tool power battery positive voltage at terminal 16.
Scan tool power ground at terminal 4.
Common signal ground at terminal 5.
Class 2 serial data at terminal 2.
Keyword serial data at terminal 7, w/TR7.
High Speed GMLAN (+) serial data at terminal 6, w/LY7 or LP1.
High Speed GMLAN (-) serial data at terminal 14, w/LY7 or LP1.
The serial data circuits are the means by which the control modules on the vehicle communicate with each other and the scan tool. There are 3 different types of protocols on this vehicle.
The class 2 serial data
The keyword 2000 serial data
The high speed GMLAN serial data
The scan tool will power up with the ignition off. Some modules however, will not communicate unless the ignition is on and the power mode master (PMM) module sends the appropriate power mode message. Refer to Body Control System Description and Operation for operation of the PMM.
Class 2 Serial Data
The data link connector (DLC) allows a scan tool to communicate with the class 2 serial data line. This serial data line is the means by which the microprocessor-controlled modules in the vehicle communicate with each other. Once the scan tool is connected to the class 2 serial data line through the DLC, the scan tool can be used to monitor each module for diagnostic purposes and to check for diagnostic trouble codes (DTCs). Class 2 serial data is transmitted on a single wire at an average of 10.4 kbps. This value is an average, class 2 uses a variable pulse width modulation to carry data and depending on the message it may operate faster or slower. The bus will float at a nominal 7.0 volts during normal operation. Each module can pull this lower during the transmission. The bus is not at battery positive voltage or ground potential during normal operation. When the ignition switch is in RUN, each module communicating on the class 2 serial data line sends a state of health (SOH) message every 2 seconds to ensure that the module is operating properly. When a module stops communicating on the class 2 serial data line, for example if the module loses power or ground, the SOH message it normally sends on the data line every 2 seconds disappears. Other modules on the class 2 serial data line, which expect to receive that SOH message, detect its absence; those modules in turn set an internal DTC associated with the loss of SOH of the non-communicating module. The DTC is unique to the module which is not communicating, for example, when the inflatable restraint sensing and diagnostic module (SDM) SOH message disappears, several modules set DTC U1088. Note that a loss of serial data DTC does not normally represent a failure of the module that set it.
You need to have all the modules on the vehicle checked an you need to take your vehicle to a qualified repair shop . You blame the PCM/ECM , I don't think so , sounds like a bad ground . Windows an locks not working are not part of the ECM/PCM . There are modules inside the doors.
Each door lock actuator is powered and controlled by the door module mounted in the individual door, but the rear integration module (RIM), which is the master control for the door lock system, determines when the lock functions are permitted. The RIM receives and examines lock function requests from the individual door modules, or from the remote function actuator (RFA) via the class 2 serial data circuit. The RIM also examines the transmission shift selector position and the ignition switch position information available over the class 2 serial data circuits. If the RIM determines that all conditions are correct for a lock or unlock function to be permitted, it sends a class 2 message back to the individual door modules commanding them to perform the lock or unlock function requested.
Your vehicle also has
Electronic Park Lock Description and Operation
If the vehicle is equipped with automatic transmission and a floor mounted console gear shift, it has an electronic park lock system (EPL). The EPL system purpose is to prevent the ignition key from being turned to the OFF position when the transmission is in any position other than PARK and the vehicle may still be moving. The EPL system consists of an ignition lock cylinder solenoid, and a park position switch that is located in the A/T shift lock control switch. The ignition lock cylinder solenoid contains a pin that is spring loaded to mechanically prevent the ignition key cylinder from being turned to the lock position when the vehicle transmission is not in the PARK position. If vehicle power is lost, and/or the transmission is not in the Park position the operator will not be able to turn the ignition key to the lock position and will not be able to remove the ignition key from the column
Fail-safe Operation
Since the operation of the vehicle systems depends on the power mode, there is a fail-safe plan in place should the power mode master (PMM) fail to send a power mode message. The fail-safe plan covers those modules using exclusively serial data control of power mode as well as those modules with discrete ignition signal inputs.
Serial Data Messages
The modules that depend exclusively on serial data messages for power modes stay in the state dictated by the last valid PMM message until they can check for the engine run flag status on the serial data circuits. If the PMM fails, the modules monitor the serial data circuit for the engine run flag serial data. If the engine run flag serial data is True, indicating that the engine is running, the modules fail-safe to RUN. In this state the modules and their subsystems can support all operator requirements. If the engine run flag serial data is False, indicating that the engine is not running, the modules fail-safe to OFF-AWAKE. In this state the modules are constantly checking for a change status message on the serial data circuits and can respond to both local inputs and serial data inputs from other modules on the vehicle.
Discrete Ignition Signals
Those modules that have discrete ignition signal inputs also remain in the state dictated by the last valid PMM message received on the serial data circuits. They then check the state of their discrete ignition input to determine the current valid state. If the discrete ignition input is active, battery positive voltage, the modules will fail-safe to the RUN power mode. If the discrete ignition input is not active, open or 0 voltage, the modules will fail-safe to OFF-AWAKE. In this state the modules are constantly checking for a change status message on the serial data circuits and can respond to both local inputs and serial data inputs from other modules on the vehicle.
Run/Crank voltage
