Question about HP LaserJet 1320 Printer
How to reset HP 1320N to factory default - HP LaserJet 1320 Printer
  • Anonymous May 18, 2009
    That doesn't work. Pressing the "Go"-Button in the power-on-process doesn't reset the printer.
  • Rigoberto Vazquez Jul 02, 2019
    While pressing the Reset button on the back of the printer, turn on the printer. Continue to press the Reset button until the printer is in the Ready state (from 5 to 30 seconds).
    New Friend:
  • 10 Answers
For me worked this:
- Turn off the printer
- Turn on the printer
- Push and mantain pushed the button on the back of the printer (near to USB connector) for 30 seconds.
- Release the button
- With 1 to 3 minutes for DHCP Server (if you have one)
The printer now have a default configuration, if you have a DHCP server your printer now have a IP Address of your DHCP Server's IP pool.
- Print a coniguration page holding down the green button until the attention LED is blinking
- Release it, 3 pages will be printed.
It is done
Posted on Aug 20, 2010
  • 1 more comment
  • meljr
    meljr Sep 10, 2012
    This was exactly what I was looking for. HP was no help, but Tom Doubrava knows. Thanks!
  • kubik256
    kubik256 Jan 29, 2013
    This will reset configuration of HP JetDirect, not the printer it self ;)
  • dawn lemay
    dawn lemay Oct 16, 2013
    can you cold reset, or restore defaults? I have a red solid error light on a canon d1320 imageclass
Make sure you record your printer's settings before performing this procedure. Holding down the printer's Green print button briefly will print any configuration information.
a. Turn the printer power off
b. Press and "hold" the green "go" button whilst turning the printer on.
c. Continue to hold the go button for at least 5 seconds and until the amber
attention light turns on (triangle with ! in the middle), this should occur
before 15 seconds elapses.
d. Release the go button.
from http://www.pcreview.co.uk/forums/thread-2290821.php
The answer byteguy gave above would be the procedure to restore and HP Computer to factory defaults.
Posted on Feb 23, 2009
    New Friend:
    Problem Solver:
  • 5 Answers
Turn off your printer, hold the reset button that should be at the back of your printer, turn the printer on again while holding the button, wait until the printer turns in "ready" state.
Hope this works
Posted on Nov 15, 2018
  • 2,229 Answers
Factory default what?
Do you need to restore the system to what it was like when you bought it? If so, you will have to boot from the system restore disks which you had to make when you bought it.
Assuming that the computer is working and you didn't make the disks, there is an item in the Program list that will let you make a restore CD or DVD.
If your computer is not working and you don't have disks, you will need order them from HP.
Posted on Feb 19, 2009
2 Suggested Answers
SOURCE:
leroyal
  • 2120 Answers
SOURCE: Resetting network settings to default on HP 2015n
Enter the ip address into your we browser annd reset in the options
Posted on Feb 04, 2009
Density Adjustment in HP Laserjet 1320
Firstly I doubt that economode is set by default, but maybe the printer is in
economode for some reason.
Secondly I would normally expect the problem to be the toner cartridge but
assuming you have checked this my suggestions are as follows.
1. Run two internal prints from the printer.
a. By pressing the green "go" button briefly.
b. By holding the green "go" button for 5 seconds.
The first print should give you an indication of the print quality, if it
is good then the printer itself is probably behaving normally.
The second print will tell you exactly how the printer is set up. This
includes whether economode is on or off and what print density it is set for
(default is 3, range is 1-5).
2. If economode is on or the print density is lower than 3 the easiest way to
fix this is to do a cold reset on the printer as follows.
Important note: This will reset the printer to factory defaults, the only
setting that is critical is the jetdirect setting. Since you stated that your
printer is a 1320 and that you are running DOS I am assuming that it does not
have an "n" (for network) suffix eg 1320n. If I am right in this assumption you
can ignore the jetdirect comments above, if it is a network printer the second
printout from 1a should provide the jetdirect information which you may need to
keep for future reference.
Cold Reset Procedure:-
Factory defaults should now be reset and you can check using 1a whether any
changes occurred.
Dec 30, 2016 | HP LaserJet 1320n Printer
How to delete previous owner WiFi data and security code
Resetting the Printer to Factory Default
Settings
Resetting the printer to factory default settings can be useful when
you are troubleshooting with the printer.
CAUTION Resetting factory defaults clears the page buffer, removes downloaded
fonts and macros, and returns all print menu settings to factory defaults.
To reset the printer to factory default settings
1 Press MENU until RESETS MENU displays.
2 Press ITEM until RESTORE FACTORY SETTINGS displays.
3 Press SELECT until the following message appears:
RESTORING
FACTORY SETTINGS
This message displays until the printer has completed the
initialization
Mar 26, 2015 | HP LaserJet 4500 Printer
How to delete former owners wireless data on HP 4500 - G510n wireless printer.
Settings
RESTORING
FACTORY SETTINGS
initialization
Mar 26, 2015 | HP Office Jet 4500 G510n
Mirror printing on hp 1320
you need post script level 3 support printer.You should buy hp laserjet 2200 or 2300 or 4250 it has default post script driver
Aug 14, 2014 | HP LaserJet 1320n Printer
Hp deskjet 1050 need to reset to factory default please, help
  • 1. Turn off the printericon1.png and remove the power cord from the back of the unit. Leave the printer powered off for at least 30 seconds.
  • 2 Press the powericon1.png button on the printer and hold the "Go" button as the printer is powering on. Watch for the "Attention" LED to turn on and stay steady.
  • 3 Release the "Go" button and allow the printer to continue powering on. The printer should now be reset
  • Read more: http://www.ehow.com/how_6809266_hard-reset-hp-laserjet-1320n.html#ixzz31kIyBHut
    May 15, 2014 | HP LaserJet 1320 Printer
    Reset factory settings on hp deskjet 1050
    Reset the Printer to Factory Default Settings Restore factory settings Restoring the factory-set defaults returns most of the settings to the factory defaults. It will not reset the page count, tray size, or language. To restore the product to the factory-default settings, follow these steps.
    1. Turn the product off. Disconnect the power cable from the product for 30 seconds and then reconnect.
    2. Turn the product on while you press and hold the Resume c02469297.gif button for 10-20 seconds. The Attention c02469293.gif light turns on.
    3. Release the Resume c02469297.gif button. The Attention c02469293.gif and Ready c02469296.gif lights cycle while the product restores factory defaults.
    Reset HP 1050 DeskJet Series Cartridge
    Jun 07, 2012 | HP Office Equipment & Supplies
    Reset hp 1515n
    ? Restore defaults-used to reset all customer-accessible menu settings back to the factory default
    settings (except language) via the control panel or software
    NOTE: This service menu item does not reset factory-settable settings, including formatter
    number, page counts, factory paper settings, language, and so on.
    NOTE: Before restoring defaults, print a menu structure report and a configuration page. Use the
    information on these pages to reset customer-specific settings.
    CAUTION: All HP Jetdirect settings are also reset. Be sure to print a configuration page before
    restoring defaults. Make note of the IP address that is listed on the Jetdirect configuration page. You might need to restore the IP address after performing a cold reset.
    Restore the factory-set defaults on the (HP Color LaserJet CP1510 Series Printer
    1. Press OK to open the menus.
    2. Use the Left arrow or the Right arrow button to select Service, and then press OK (Select).
    3. Use the Left arrow or the Right arrow button to select Restore defaults, and then press OK.
    The product automatically restarts.
    Jul 13, 2011 | HP LaserJet CP1515n Printer
    How do you add this printer to the network?
    for networking take the configuration page & note down the default ip add then open the internet explorer & note down the default ip & enter you will conect the printer directly then change the ip add as per ur requirement & uncheck the dhcp .
    hope ur problem will be resolve...
    Jul 01, 2010 | HP LaserJet 1320 Printer
    HP Laserjet 1320n Admin Password has been forgotten. Need to change the IP address, but cannot access the system. Any suggestions?
    joed_calcule
    If you changed the password from the default one but forgot the one you set it too all you really can do at this point is set the printer back to the factory defaults. The menu options below will help you do this.
    Advanced Printer Settings
    Settings tab
    Resets = Change all the printer settings back to the factory default settings.
    Let me know if you have any more problems or questions
    Issken
    Feb 17, 2010 | HP LaserJet 1320 Printer
    HP Laser Jet 1320n series
    The HP LaserJet 1320 has a USB port and a Parallel port.
    The HP LaserJet 1320n has a USB port and an Ethernet port.
    USB-to-Parallel converter cables, like this one, are designed to attach a parallel device to a computer's USB port.
    But you need to do the opposite (attach a USB device to a computer's parallel port). A USB-to-Parallel converter cable will not do this.
    Feb 29, 2008 | HP LaserJet 1320n Printer
    HP LaserJet 1320 Printer Logo
    40,274 people viewed this question
    Clive
    Clive
    Ekse
    Thomas F. Schneider
