Started to leak today making a noise when turning the steering she'll 360 :-)
SOURCE: power steering fluid leak
check the lines to the rack and pinion,,,,cpild have a ruptured line
SOURCE: power steering went out and making a loud noise when turning.
yes power steering is most likely very low , repair leak , as the fluid is flameable
SOURCE: 2002 Jeep Grand Cherokee leaking coolant and power steering fluid
Just a heads up, $10 bucks will buy you a seal kit for the P.S. pump. I topped mine off for a couple months, then the oring on the high pressure line (from pump, front center) blew and dumped the reservoir in a matter of miles.
The line can be a stinker to get off, recommend driving the car for a few minutes to heat up the pump a little. Don't forget the 20MM wrench.
SOURCE: power steering hose leak
as long as you use a flair nut wrench on the fittings it's not that hard. Since you aren't going to use the old hose over, if the nuts are frozen you can break the line off and use a socket to get them off. Don't loose any "o" rings (new kit comes with them as needed but make sure you know where the old ones are. New lines are often a slightly different shape than old one...make sure line is not rubbing on anything or it will wear through.
After filling, turn the wheel gently all the way to one side, then the other and re-check level. Most times any noise at pump will disappear after use,as any residual air bleeds out.
SOURCE: My Isuzu trooper 1990 makes a squeaking sound
The power steering fluid level is low or the v-belt tension needs adjusting.Its not likely to be the aircon comp.Look at the v-belt.Adjust if needed and also see its not cracked or too shiny that would allow slipping.If in doubt,replace it.It will be the problem.Hope this helps
Testimonial: "spot on!! thnk god i decide to seek opinion thru fixya..I was going to send it to a mechanic!!Save me lots of $$$"
