Error says to turn printer off and on, which I've tried multiple times only to receive the same error
SOURCE: m looking for epson stylus 400 printer driver for
Necessary you driver are found with system Windows If say in other words, that they already recorded on your hard disk.
System Itself will find them for you during process of the installing the printer.
Exist for Epson Stylus 400 ESC/P2 Also for for Epson Stylus Color 400 ESC/P2 You simply it is necessary to install printer manually through menu
1) Control Panel
2) Printers and faxes
3) Add printer
4) Next, Next, Next
5) you must choose brand "Epson" and your model of printer.
6) Next, Next .............
Good Luck !
SOURCE: Get this Error message:
Ensure that directory is delete when you uninstall and there mates ie........ /EPSON/......whatevers.
Use a new set of downloaded drivers from elsewhere, not the same ones if you can help it and if you cant it is because they dont really exist, ones that work will be many places....... ensure full compatability to your mac OS, I can't help you much there but I can assure you it isn't a problem with the printer it is a mac/driver issue. Hope thaty helps a little cheers
SOURCE: Epson PLQ20 Passbook printer Problem:"comunication Error"
Hi, Check your cable connection. Check for updates from Epson. Restart your computer . Good luck.
SOURCE: Epson RX595 says "Error-paper jam" but no paper in printer!!!
I got my printer to work (finally! #$^%$%) by moving the ink carriage back and forth a bit gently and then I sprayed a small amount of WD40 on a lint free small cloth and wiped the silver bar inside with it. I slid the carriage slowly from one side to the left and it seemed to stick less. I thought my printer was broken so I figured it couldn't do any more harm and lo and behold it worked! My printer went back to the normal screen after turning it back on and I am finishing the print job that I never thought would happen. YAY!
