Question about Kitchen Selectives Over Easy Omelette Express
Manual - kitchen selective omelet maker
Manual
Kitchen aid growls at slow speed
Hello again, BCPSBT. I’m sorry, but I’m just a little confused because neither the Part List nor the Owner’s Manuals go into any detail about changing/replacing the lubrication grease in your mixer, so I’m not sure what you are referring to when you say your system ‘times out’ when you get to page 10 when you attempt to download it?
The Parts List manual is only 8 pages. Are you perhaps attempting to download the Owner Instruction and Recipe manual instead, which is much longer?
The reason you need the Parts List Manual K45SSWH-0.pdf (2730.37 KB) is to see the ‘exploded views’ which will aid you in the disassembly and reassembly of your mixer. The best instructions for regreasing you mixer are from these two websites:
I’m sorry I don’t have more specific step by step instructions to offer you. Sometimes you have to step out in faith and trust that you can actually accomplish the work yourself.
I wish you good luck in completing your ‘oil’ change.
Good luck and have fun. I hope this provides a little more clarification. Howard, Burke, VA
If this solution was helpful, please rate it, thanks! – hslincoln
May 07, 2010 | KitchenAid K45SS Classic Stand Mixer
I have a kitchenaid 5ksm150(UK), I recently purchased an
Hello KELPIES52. I see you have two postings, with some minor differences. You say purchased an “ice-cream maker attachment” in the US and my first clarification question to you is, did you purchase the KA Ice Cream Maker, Model KICA0W, or some other brand that said it was compatible with KA mixers?
If you did buy a KA ice cream maker, then it should fit all KA models, including yours. If you purchased another brand of ice cream maker, then it may never be truly compatible, and there’s the rub.
First regardless of what brand of ice cream maker you purchased, you should have both your KA mixer’s Parts List manual and both the KA Ice Cream Mixers Parts List and Users Manuals in hand. If you're lacking them, you can download a PDF version from the KA website at: http://www.kitchenaid.com/flash.cmd?/#/page/home.
Click on Customer Care>Locate Manuals & Guides> and enter the 6 character model number, in your case use 5KSM150, for you mixer and select the file 5KSM150PSEWH4.pdf (777.26 KB) listed under Parts List (1113) (you can actually choose any file sized 777.26 KB; they are all for the different color UK models) and then check to verify this matches your mixer model. This is a good file to have on hand if you ever decide to troubleshoot and fix your mixer by yourself.
After downloading your mixer’s Parts List manual, enter the KA Ice-Cream maker’s 6 character model number, KICA0W (that’s a zero and not an “O”). Download the Part List and the Use & Care Guide manuals (even if you don’t have a KA ice-cream maker) for your future reference.
If, perchance, you have the KA ice cream maker, turn to page 5 for instructions for mounting the drive assembly onto your tilt head mixer's agitator shaft. The KA ice cream maker’s drive is designed to fit over the spring and groove pin (stud) on the agitator shaft.
On the other hand, if your ice cream maker is not a KA model, you can still remove the collar, spring and groove pin if you’d like to give it a try. You will need a punch drive with a smaller diameter than the groove pin, a hammer, steady hands and plenty of patience. Tilt your mixer’s head up and rotate the planetary agitator shaft so that the flush end of the pin with the agitator shaft is facing you (the extended part of the pin is facing away from you). Align your punch drive on the end of the groove pin and give it a good whack; repeat until the pin starts to come out the other side of the agitator shaft. Continue tapping until the pin comes completely free. (Note the groves on the pin as you will need to orient the groove pin the same way when you reassemble the spring and collar on the agitator shaft when you’re finished making ice cream). Once the pin is removed the spring and collar will easily come off and then you can attempt to mount the ice cream maker drive on the agitator shaft. Caveat Emptor! Good luck, I hope this helps. Howard, Burke, VA
If this solution has helped you, please rate it, thanks! - hslincoln
Feb 22, 2010 | KitchenAid 32685 Mixer
Need instruction manual for Waring Primo Pasta maker
Here is one:
http://kitchen.manualsonline.com/mdownloads/f94c65cf-4df5-41e2-aae4-7021aed15dfa.pdf
Could someone tell me how much flour the flour cup holds, compared to a regular measuring cup?
Apr 02, 2009 | Food Mixers
Can the Kitchen aid accessories fit the Wolfgang puck stand mixer
If you happen to have a friendly toolmaker with a small metal lathe it should not be too difficult to modify KITCHEN AID accessories that fit on to the front powwer outlet. However Puck Stand Mixer accessories are occasionaly offered on the Web. Meat grinders are very common and original Puck pasta maker have also been seen. Get searchin'!
Dec 01, 2008 | Wolfgang Puck Stand Mixer
Instruction manual for oster kitchen center
how do iget the driver gear off
Sep 03, 2008 | Food Mixers
OSTER KITCHEN CENTRE
Hi there i do believe i have a solution to your problem
A full list of mixer fro Oster is available at this web site
http://www.oster.com/CustService.aspx?content=manualList&cid=1542&catName=Mixing
The customer service also is very friendly and can answer to all your question or concern.Consumer rating for small appliance is very questionable because the items in question are very generic and they are all realtes to the same market segment
Jun 18, 2008 | Food Mixers
Oster kitchen center driver removal
The customer service will help you to find the right answer to your question.The do also have technical repair center or they will tell you how to return the item for replacement.i used before and they work good
Jun 12, 2008 | Oster Food Mixers
Kitchen Selectives Over Easy Omelette Express Logo
139 people viewed this question
Top Kitchen Selectives Food Mixers Experts
Bruce Showalter
Marvin
Marvin
eyecam
Are you a Kitchen Selectives Food Mixer Expert? Answer questions, earn points and help others
