My dishwasher, model bosch shu43c05uc, won't change cycles. when i start it, it stays in the first cycle and never changes. i tried the reset but it didn't change anything. i'm pretty sure it's a sensor that is messed up but i have no idea which one it is. please help!!! thanks
Locate the tech sheet for your machine. It can be taped to the back of a panel or on top of the machine or usually behind the lower panel. The tech sheet will tell you how to enter the service program and check for error codes. It sounds like the control board is failing.
You can check at Appliance Parts Pros or Repair clinic for parts for your unit.
Hope this helps.
SOURCE: Bosch Dishwasher, SHU 5300 - Cycle stuck on 2H cycle
yes it needs a new control and its pretty easy to replace..
SOURCE: Bosch dishwasher whining
if you listen to the appliance and the noise is louder on the rhs and low down this is probably the main wash motor they sometimes do whine if you can live with the noise leave it alone if not you basically have to take the whole applianmce apart for access to the motor costly repair would take a trained pro about 90 mins to replace the motor
if the noise is coming from the front of the appliance more to the lhs and is intermittant ie when it first starts up and then about half way through its likely to be the drain pump relitively easy to replace and you dont have to take the appliance to bits just go at from the front
good luck
SOURCE: Bosch dishwasher: won't fill with water
The flood switch is tripped. This is located under the unit. Unplug or flip the breaker to the dishwasher, take off the black kick plate under the door, 2 screws, and you will see the white plastic "pan". The flood switch is located where you can't really see it but it is on the left hand side wall and is made of styrofoam. The best thing to do is to put some rags in the pan, this is not easy because there is little room to put them, and soak-up the water that has filled the pan. Eventually you will get enough water out that the float will deactivate the switch. What you hear "running" when you turn it on is actually the drain pump, it get activated when the flood switch is tripped.
SOURCE: Bosch
f is fill fault to much or not enough water or water in the sump white plastic base the f code will not go away until you solve the problem when the f code shows up the drain motor will run all of the time
