Is it possible that my tv is digital only for HDTV, and only analog for all other broadcasts?
I use an antenna...and with the antenna plugged into the HDTV-AIR jack, I get HDTV broadcasts very nicely. But since the switch over from analog to digital broadcast, I do not receive DTV. Yes, I have plugged the antenna into the other antenna jack TV-CABLE. I have also programmed the set properly for either of the modes, I think?
Am I missing something here? I thought my tv was all digital! Do I have to buy a converter box for DTV broadcasts?
A search online has been fruitless to find any info on this tv, and the owners manual is lost.
Any help would be appreciated.......Thank You
Try going into your menu and putting the input to Antenna, then reprogram, let me know!
You do have the ATSC tuner which is able to receive over the air dtv channels ( if available ). If you are receiving even just one, then it's doing its job. It is not mandatory for all stations to switch to HD if they do not want to now. June is the dead line now. So, in short some stations are still broadcasting in analog.
I did do menu and selected antenna and then programmed. I get now only a few channels still broadcasting in analog, and no DTV.
