After removing fuser and drum to clean up toner spill I have a f36-1 error i need to reset .Dose anyone have the reset code?
SOURCE: konica 7020
Did you blow it up, probably not.
Click this link for the everything.
http://www.kmbs.konicaminolta.us/content/support/supporthome.html
Or click on this link for the specific manual.
The error codes you seek are not in the manual, you'll have to call Konica to tell you what they are ... call Konica at (860) 683-2222.
Hope this helps. Rate a fixya!
SOURCE: konica 7020
F26-1 at power up.
[Description]
F26-1 at power up.
[Solution]
PROBABLE CAUSES:
1. The TDS (Toner Density Sensor), in the developing unit, has detected a depletion of toner.
Note: This may have been caused by the customer making an excessive amount of copies while the machine was out of toner. It may also be caused by a bound toner addition system.
Clean all toner from the toner recycle and toner supply assemblies. Confirm that the gear mesh between the toner supply auger drive gear and toner supply motor (M4) is flush. If toner supply conveyance is normal and the toner cavity is empty, install a new toner cartridge (Item #950236) and then perform the following diagnostic mode to replenish the developing unit with toner:
a. Access the 47 mode (power the copier ON while pressing the 4 and 7 keys).
b. Enter output code 54.
c. Press the START button.
Note: Toner will now be added to the developing unit and stop automatically when target level is reached, although it will not run any longer than 3 minutes.
d. Power copier OFF/ON to return to normal copy mode.
Note: Perform the following 25 mode software switch settings to minimize the amount of copies that can be made, prior to copy inhibit, when the ADD TONER message is displayed:
- Access the 25 mode (hold down the 2 and 5 keys at power ON).
- Select [1] (SOFTWARE SW).
- Using the up and down arrows, scroll to the following software switches and set them as follows:
a. 4-0 set to 0
b. 4-1 set to 0
c. 4-2 set to 0
d. 4-3 set to 0
- Power OFF/ON to return to normal copy mode.
Notes:
A. These setting will allow the ADD TONER message to be displayed immediately and only allow 100 copies to be thereafter.
B. Copier inhibit will automatically be released when a new toner cartridge is installed.
2. The toner conveyance gear is worn. The toner conveyance gear is driven by the toner supply motor located on the toner supply unit.
Replace the toner conveyance gear (p/n 26NA32680).
I may be able to get the manuals for a nominal charge. [email protected]
SOURCE: Konica 7020 copier
replacing the drum will not fix the F-26-2 code
the L detect will need to be done on the copier to clear this code. it will require developer. never run this adjustment without replacing developer. the 7020 and 7030 series will error out if the developer is replaced and L detect is not done or vice-versa
to fix this replace developer then cut the machine off. hold down the 3 and the 6 button while cutting the machine on, go to (1)voltage adjustment then scroll down through approx 6 or seven adjustments to L detect. make sure all the doors are closed and the copier is ready. hit start, the machine will take about 5 minutes to complete this adjustment, it will display "ok" in the screen when it has successfully completed the adjustment. if it displays 006 pull the developing unit out, and clean the contacts towards the backof the developing unit. sometimes developer droppings can cause this code.
after it has completed L detect now cut the machine off, hold down 2 and the 5 button while cutting it on. go to counter and reset the pm counter.
SOURCE: Konica 7022 F-26-3/2 L detect 0004 Konica 7022
Details
Subject:
Background, overtoning, and/or F26-x codes.
Description:
Solution:
PROBABLE CAUSES:
1. Overtoned developer.
Install fresh developer (PCUA 950237) and run the L-detect adjustment. To run the L-detect adjustment, perform the following:
a. Enter the 36 mode (power the copier ON while pressing the 3 and 6 keys).
b. Press [1. HV adjustment].
c. Press [Next] several times until the display reads [HV adj (L detection adj)].
d. Press [Start].
e. When the adjustment is complete, the machine will stop and a value is displayed in [RESULT].
f. If the developer was sampled properly during the L-detect adjustment, the value displayed in [RESULT] will be in the 60-75 range.
g. If the L-detect adjustment [RESULT] value is outside of the 60-75 range, than the TDS (toner density sensor) should be checked.
2. Failed TDS (toner density sensor).
To check the TDS, perform the following:
a. Remove the IP unit (if an IP unit is installed).
b. Remove the rear and left rear side cover.
c. Remove the board cover/D (p/n 26NA73280) for access to the PRDB.
d. Enter the 36 mode (turn the machine ON, while pressing the 3 and 6 keys).
e. Select [1. HV adjustment].
f. Press [NEXT] several times until the display reads [HV adj. (Toner auto supply)].
g. Locate TP14 (TDS AN) in the middle of the PRDB above CN 25.
h. Using a voltmeter (20V DC range), place the red meter lead on TP14 and the black meter lead to frame ground.
i. Press the START button on the control panel.
j. The analog voltage reading on the volt meter during sampling should be (with properly toned developer) between 1.2 and 2.0VDC. If the voltage reaches 2.0VDC, M4 (toner addition motor) will turn on and add toner. When the toner auto supply adjustment is finished the voltage should read approximately 1.8VDC.
k. If the voltage reading is not within this range, replace the developer (PCUA 950237), TDS (p/n 26NA88040) and run the l-detect adjustment while monitoring TP14 on the PRDB.
3. Failed write unit (the TCSB monitors dot pattern patches created on the drum and adjusts the laser output for Maximum Power Control).
If developer has been replaced, L-detect run, the TDS voltage checks, and the developer is still overtoning (M4 continuously adds toner), replace the write unit (p/n 26NA-6503).
4. Clogged machine filters.
Check all machine filters to verify they are not clogged. Clogged cooling fan filters prevent proper ventilation which can cause the adhesive on the write unit glass cleaner to melt due to high internal temperature, causing smears on the glass.
Note: Information provided by Matthew Kennedy, Perry Corporation.
SPECIAL NOTE: Solution contribution by Don St. Onge, Workgroup/SSD
Attachments:this is additional information on f-26-2
and i have given you info on f-26-3
you should revue all the information
hope that helps
SOURCE: konica minolta EP2010 error code c05
I have a Konica Minolta CSPRO EP1054 (in the Middle East)
I accidentally plugged the EP1054 copier into a 110V outlet instead of
the 220V. Immediately the malfunction code (error code) of "C05"
appeared along with the "Call Tec Rep" indicator light (wrench).
I followed the instructions posted by "Soul Visitor" ... i.e., I found
the "Trouble Reset Switch" (not shown in the user manual) by opening
the upper back panel and pressing the small black button in the lower
right hand corner of the middle circuit board (green).
It worked perfectly!
