SOURCE: Is there a way to turn on the WiFi function
Try to disable the network card using the Device Manager.
SOURCE: BIOS POST message cannot be displayed and Setup does not run
As soon as your computer turns on, start pressing F2 simultaneously until it enter the CMOS setup.
SOURCE: I was told press F2 simultaneously on startup, nothing happened
You need not to press F2 or tab or escape unless you need to do so. If your system is ok, it'll automatically boot up, but if there's boot up problem with your system, then that's different. Thanks for using FixYa.
SOURCE: when i turn on my eee pc i get the message "Press
Please pull out your hard disk and put it back after 10 seconds. Your laptop will be start as normally.
Thanks
Maybe you are not giving it enough time to get into the setup.
Let it sit for a while and see what happens.
