I just bought a new hisense 40 inch smart led tv and misplaced the manual. I want to add a sound bar but I am unsure of what type of audio output my tv has, i.e. optic, analog, etc.
SOURCE: Im trying to connect my
You will be needing a RCA Digital TV box converter or Digital RCA TV box converter. This converter will be the link between the Sound bar system and TV.
You should find this converter in any electronics accessories store within you vicinity or check walmart store close to you or order it online from walmart (But I don't recommend ordering online because of it's problem sometimes).
Check the back of the converter, it should have an input for Digital and RCA output and vise-a-vise.
Take a look at this Walmart link; http://www.walmart.com/ip/RCA-Digital-TV-Converter-Box-DTA800/8343230
I hope you understand the above.
Good luck.
SOURCE: Trying to connect digital audio output optical terminal to existing analalogue hi-fi amplifier
there should be on the tv out a red and white rca output or a coaxial, your yamaha my be too old to deal with the outputs on the tv. at the jvc website you can download the manual for this tv.
SOURCE: No Digital Audio From Sharp LC-37D64U
Try changing the the Audio Setup in the Digital Setup Menu.
If you have your manual, go to pg 11 and pg 28 for Digital Audio Output. If you need a copy of your manual, here's the link.
http://www.sharpusa.com/products/TypeManuals/0,1083,127,00.html
Page 11 has info on the problem and page 28 to solve it.
If that doesn't work, I would try downloading the latest software to fix is problem. Page 28
http://www.sharpusa.com/products/support/options/1,2310,,00.html?model_num=LC-37D64U&s_func_disp_id=27&x=42&y=11
SOURCE: Audio with digital channels, no audio with analog channels
I was getting a constant mono setting for all channels with no option to set it to stereo. I called Sharp, and they said that in order to receive stereo sound, you cannot use a standard coaxial cable. You need an S-Video or HDMI cable. This not only resolves the mono audio issue but also resolves the analog (vs. stereo) issue. Hope this helps!!
