Kohler K-3489 Cimarron Comfort Height Elongated Toilet With Left-Hand Trip Logo
Posted on Feb 26, 2013
Pfister kamato How do we adjust the water level in the bowl.It is too low...email at [email protected] you
Can the pfister kamato e70w toilet be refitted with an old style flapper valve to control excessive water wastage ?
Go to an ACE hardware and talk to the plumbing dept sales representative. They will know.
Dec 16, 2016 • Home
Water leaking into bowl
I have the exact same problem with the pfister toilet.Anybody with ananswer??
When we flush the toilet there is never enought water left in the bowel after...do i get more water
Make sure the small toilet fill tube in the tank is still running into the tank overflow tube.
Needs two flushes to empty bowel
might be that the water level in the tank is to low. if both buttons release the same amount of water then you have to increase the water level in the tank by adjusting the height of the floater on the inlet valve. look inside the tank and there should be a WL mark meaning water level should be set to this level minimum.
3helpful
Toto Drake does not fill the bowl to the level of other same toilet. Water level in bowl is low.
Water Level Adjustment
1. To adjust, simply turn upper half of valve counter-clockwise to unlock, pull up till water line on valve is level with water line marked in tank, Fig.C then turn clockwise till valve snaps into locked position.
2. Turn on water supply to fill tank.
3. Tamper proof key is optional, and may be used to simply to prevent further adjustment once final setting is achieved. Fig D
2answers
Can't adjust flush time for complete flush, low bowl water level
flush time depends on how much water is in it,
the water level flote has an adjuster on it, but i cant rember were it is,,, sorry
4helpful
Low water level in toilet bowl
Sorry, but there is no way to raise the water level in the bowl of a low-flow toilet. The water level is determined by the height of the internal trap, usually visible from the side of the toilet (that squiggly little bend). If the toilet is not flushing satisfactorily, you can make adjustments to the water level in the tank and adjust the closing of the flapper. If the problem is odors, flush half way through your business or turn on the bathroom exhaust fan. If you found this answer helpful, please don't forget to rate it.
Apr 09, 2009 • Bemis Home
Top Kohler Home Experts
john h
ZJ Limited
ZJ Limited
Are you a Kohler Home Expert? Answer questions, earn points and help others
