Model # t3522, i need to see the system panel connector information to plug back into the motherboard, plz help
SOURCE: need help bigtime
Here Mouthy22 the diagram:
If you need a manual for your MOBO just click HERE..
Enjoy!
Thanks,
are those all seperate connectors for the button? Or are they all together on one block? Should be something near bottom right hand corner of mobo saying pwr, hdd, sw, snd, led, that kind of thing
SOURCE: reset/power/led etc..lead connections
to,
davewhisner
you have to specify your model no of mother board & brand also full code than i will saw you how to connect that ports with figured out,
THNX
SOURCE: need front panel connection diagram power switch lrf connectipns on 9 pin connector on motherboard
Hi u can easily solve this problem.
open your computer cover and and see the motherboard front panel connectors. a use of screw driver touch any two front panel connectors if any led or switch working this condition you can note this and connect successfully. one by one touch all penal connections and u will be solve ur problem thanks mukesh kumar
[email protected]
SOURCE: Bluford E139765 mainboard power panel connector
Look at the board really close you'll see it at the bottom right corner, SPKR, RSW, PSW, and so on, try one at a time, until you get it
