Coby Kyros MID80244G Tablet Logo
A
Anonymous Posted on Feb 26, 2013
My coby kyros mid8024 is not working, the android is not comming on
5 Related Answers
Anonymous
  • 1940 Answers
  • Posted on Feb 24, 2011
SOURCE: Process com.appslib.vending on my coby kyros tab.
Installing the Windows software, Kryos USB drivers, and updating your Appslib:
  1. Download and install The Java Development Kit 6 here: https://cds.sun.com/is-bin/INTERSHOP.enfinity/WFS/CDS-CDS_Developer-Site/en_US/-/USD/ViewProductDetail-Start?ProductRef=jdk-6u24-oth-JPR@CDS-CDS_Developer
  2. Download and unzip the android-sdk-r07-windows.zip file to the C: drive on your computer: http://developer.android.com/sdk/index.html
  3. Go to the android-sdk-windows folder that you unzipped
  4. Launch SDKManager.exe
  5. Under choose which package to install, click accept all. As a part of what it is downloading, it will download the Android USB drivers. This part will probably take like 30 minutes or more to complete.
  6. Once the download is done, close the SDK Manager.
  7. You should now see a folder called usb_driver. Open that folder.
  8. You will see a file called android_winusb.inf. Replace that file with the one downloaded here: http://rapidshare.com/files/435451166/android_winusb.inf
  9. Plug in your Kyros device. Windows will still not find the driver for the device, but go into the Device manager, and select AndroidEclair, and update driver, browse my computer, let me pick from a list of device drivers on my computer.
  10. Click "Have Disk" and browse to the c:\android-sdk-windows\usb_driver folder. Double click on android_winusb.inf.
  11. Select Android ADB Interface.
  12. It will then come up with some messages about this is unsigned or something, are you sure you want to do this, click yes or continue.
  13. Then it will install the driver and detect the kyros.
  14. Download appslib_2.apk here: http://files.appslib.com/apps/marketplace/v2/Appslib_2.apk
  15. Make sure you have external SD card (optional)
  16. Make sure your wireless is setup, on, and works.
  17. Under Settings (press the M button on the home screen to access settings)
  18. Select Applications, and make sure Unknown Sources is checked.
  19. On the Force prompt, select wait.
  20. If step 19 doesn't work you have 3 choices: A: call their customer service B: return to the home screen or C: Go to step 21
  21. Get the Droid Explorer for your Windows PC
  22. Make sure your KYROS is connected to the PC and launch DROID Explorer.
  23. Now you can uninstall apps or install apps.
  24. You need to download Appslib_2.apk, if you haven't already, click here and download the file to your PC.
  25. Uninstall the old Appslib before you install the new version Applib2.
  26. Transfer the Appslib_2.apk file to the [DOWNLOAD] folder on your device. Unplug your device.
  27. Open the File Manager on your tablet, go into the Download folder, and tap twice on the Appslib_2.apk file that you will find there to start the installation.
  28. Follow the on-screen instruction to install this newer version of the Appslib applications.
  29. At the end of the installation, select: "Open".
If you have an app that won't install correctly or is not working at all, you could try and download the Appslib update or upgrade here: http://www.cobyusa.com/?p=prod&prod_num_id=10498&pcat_id=1013
An alternative to the Appslib is Andexplorer, available here: http://www.lysesoft.com/products/andexplorer/index.html#download
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Anonymous
  • 12 Answers
  • Posted on Feb 28, 2011
SOURCE: where can i get android 2.1 for my coby kyros
From what I've read, the tablet comes with Android 2.1 already installed on it. Try going to Settings->>About Tablet and making sure that Android version is 2.1.
iiiears
  • 14 Answers
  • Posted on Apr 08, 2011
SOURCE: everytime i turn on my
Link
phandroid.com/2008/10/25/how-to-reset-your-g1-and-start-from-scratch
"It came time to part with my review unit of the G1 (Thanks T-Mobile!) and send the phone back to its rightful owner. But what about all the personal info on the phone? The apps, texts, e-mails, AIMs and all that jazz? A quick search of AndroidForums.com turned up an easy way of restoring your G1 to factory settings:
if you power off your phone and hold the home (shaped like a house) and the end (red hangup button) for about 20 seconds you get a triangle with an exclamation point and a picture of the G1.
Now all you have to do is pop open that pretty QWERTY keyboard and there are several keyboard shortcuts you can use to accomplish what you want to do:
Home+Back reboot system now - (Soft Reboot)
Alt+L - Toggle log text display - (Toggles between the exclamation and menu options)
Alt+S - apply sdcard:update.zip - (Not brave enough yet)
Alt+W - Wipe data/factory reset - (What I chose, had to re-register, out of the box settings)
thee last option (Alt + W) and restored my borrowed G1 to factory settings. I'm sure the soft reboot could be helpful too, should you run into problems a troubled application may have caused. We didn't try the other 2 options so use at your own risk.
By the way, I couldn't live without a G1 so I made the leap and purcahsed a G1 with a T-Mobile service plan. I'm still a loyal Verizon customer and will simply have to keep both plans... but I NEEDED the G1. So basically, you can expect the application reviews and insight you've gotten at phandroid.com to cotinue since we've got our very own device now!
[Via Android Forums]
Anonymous
  • 1940 Answers
  • Posted on Nov 09, 2011
SOURCE: I have a coby Kyros tablet and it's not comming on the sreen is dark and the touch arrow that allows you return to the previous page is a illuminated
It sounds like your screen is damaged or faulty and will need to be replaced.
You will have to contact Coby Support to get this fixed:
[email protected]
General product support and inquires: 800-727-3592
- Monday-Friday (8:30AM-5PM EST)
- Saturdays (9AM-5PM EST)
Anonymous
  • Posted on Mar 31, 2012
SOURCE: will a pny micro memory card work in my coby kyros?
Any Memory Card That says Micro SD Card should fit in the Coby Kyro, The SD Card is one of the smallest cards there are.
Just got a MID8042 want to watch from portable hard drive, will this work? t
Amazon.com : Coby Kyros 8-Inch Android 4.0 4 GB 4:3 ...
www.amazon.com/Coby-Kyros-8.../B0075W8Y1S
Amazon.com, Inc.Coby Kyros 8-Inch Android 4.0 4 GB Internet Tablet 4:3 Capacitive .... The Coby Kyros MID8042-4 Tablet is a powerful and flexible internet and .... Simply connectyour Coby Tablet to your HD TV with an HDMI Cable is the ticket to .... I bought the Coby 8042 as a low cost portable device I could take with my while traveling.
Coby Kyros 8-Inch Android 4.0 4 GB Internet Tablet 4:3 ...
www.amazon.com/Coby...Internet-Tablet/.../B0093XT...
Amazon.com, Inc.
Rating: 3.1 - ‎1,377 reviews
Amazon.com : Coby Kyros 8-Inch Android 4.0 4 GB Internet Tablet 4:3 ... SANOXY® PU Leather Carrying Case For 8 inch Tablet Stand w/ USB ... With sleek and stylish Coby tablets, you can relax and enjoy your favorite music, 1080P HD videos, ..... Picksup home wi-fi & mobile hotspot (wi-fi from my phone) just great, never ...Missing: mid8042
How to fix kyros coby mid8024 tablet
Sounds like a corrupted kernel. The only thing you can do is download adb tools and then download the original Coby files for android. without having to do alot of research(if you dont know how to, you will have to research) you can go to Androidcentral.com go to the coby section, in the forum. There you should be able to find the step by step method. Sorry but this would be about the best help I can give you with out actually doing it myself.
1helpful
How do i factory reset a coby kyros mid8024?
There are two methods of reset Coby Kyros MID8024:
1. Soft Reset
2. Hard Reset
Steps for Soft Reset:
  • Take out the battery.
  • Reinsert the battery.
  • Press and hold the power button for 10 seconds.
That's soft reset. If your device doesn't load after this, try hard reset.
Steps for Hard Reset:
  • Switch off the device.
  • Press and hold Volume Up + Home Button + Power Key.
  • After 2-3 seconds, release the Power Key.
  • You will enter boot screen, Select Wipe Data / Factory Reset.
  • Select Yes.
This will delete all the files including apps, personal data stored in phone memory. Don't worry it doesn't wipe off the SD Card so you should make a backup of your files stored in phone memory.
1helpful
2answers
Need to change my settings back to english
use this manual refer to the icons and try to serch for the same in your korean or either count manual lines until you reach same position like in english How to Change the Language in Android
http://www.wikihow.com/Change-the-Language-in-Android
How do I rest everything on my android model number MID7014
To find out the steps require to reset your Coby Kyros MID7014, you will first have to contact Coby's customer support for more assistance. You can find out their contact details on http://www.cobyusa.com/?p=kyros-support.
My coby kyros mid8024 is dead! all it does when i turn it on is show "COBY" next i hear a clicking noise then all the lights for each button go out shortly after the "COBY" on the main...
It's sounds like it's down for the count. Take it to a repair shop. They may or may not e able tix it. Chances are good your going to have to buy a new device. I had that same problem and I ended having to purchase a new device .
9helpful
3answers
I bought a coby tablet mid7015 but can't access facebook from it,they said I should download the application by clicking onthe appslib icon but wen I do so nothing happens, it just keeps me waiting...
It might be the version of the Android on it. If you use Android 2.1, then you have to upgrade it to Android 2.2, then you will be able to play Flashcontent.
But bad news is, that you have to wait, until Coby releases an Android 2.2 upgrade for Kyros (http://www.androidtablets.net/forum/coby-tablets/3663-coby-kyros-7015-tablet-questions.html), because if you upgrade your tablet PC from elsewhere, then it might be malfunctioning.
Top Coby Tablets & eReaders Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Kolbrun...
Are you a Coby Tablet and eReader Expert? Answer questions, earn points and help others
