Question about Korg Legacy Collection
Triton Le I have the Korg Triton Le and i have it set up through midi with my MPC2000.. I am trying to record the midi tracks into my mpc but the only track that will record into the mpc is track 1. i cant get the other tracks to record into the mpc.
  • 3 Answers
When you are setting your midi track on the mpc are you changing to 2A-Device02 for the 2nd track? 3A-Device02 would be the 3rd track and so on. Let me know if that helps. you should make a new track for each instrument you record from the triton to the mpc, helps when dumping.
Posted on Mar 24, 2009
SOURCE:
I need the mother board for korg triton Le i need help where i can find it and how much. thanks
There should be service center near your house.OR better u give us your location and about cost there is range in every in product it depend on u what suites u better
Jan 07, 2011 | Korg Legacy Collection
How do I play the O1WFD sequencer through the Triton Pro X??
Here is a link to a site with all the info you need:http://forum.recordingreview.com/f18/midi-troubleshooting-101-a-5208/ You will need to join which is free and well worth the time. I also recommend downloading the free book Killer Home Recording Setting UP.
May 16, 2010 | Music
I own a korg triton music workstation sampler and when I create a sequence using the 16 tracks and I want to make a song using a que list all of my inserted effects on all the instruments do not work when...
you need to ensure that you have recorded the midi command to select each effect and level of that effect. this can be done in the midifile. you need to start record and very quickly at the start of the song you need to select the effect and set the level, whilst in record. this should write the setting into the song. you can check this if you use an external sequencer.
Dec 13, 2009 | Music
Still dont get it
Hi Mark.
Siorry, but because of a fault with the system I am not able to reach you on the other thread.
Normalizing tracks means leveling volume settings for a group of tracks or samples to mix or combine them together without troubles like the ones you got.
to normalise tracks you can use the function built in on the Korg studio, see normalize in the software help.
When operating on MIDIs also remember that MIDIs are recorded on different channel (example drums, guitar bass guitar).eg:bTd Aerosmith MIDI archive
When you use them on a sequencer, and you operate on the volume, ensure
Mar 29, 2009 | Korg Legacy Collection
A ''static'' sound coming from ALL outputs of Korg Triton
try cleaning ALL the contacts involved with Caig DeOxit (D5, S5. F6, G5, etc.) products*, they work very well. e.g.; cables, inputs, outputs, and (if you're confident) all the contact points "under the hood". this static you speak of sounds like less than stellar contact points and can addressed at home if you've the motivation to DIY.
* amazon.com/D5S6-Contact-Cleaner-F5S-H6-FaderLube/dp/B00HNV7WI2?SubscriptionId=AKIAILSHYYTFIVPWUY6Q&tag=duckduckgo-d-20&linkCode=xm2&camp=2025&creative=165953&creativeASIN=B00HNV7WI2
Mar 31, 2017 | Music
Trouble with hooking mpc4k and korg triton pro to mbox
you will want your triton midi-in to go to your mpc midi-outB
then your mpc midi-inA to go to your mbox
your mpc midi-outA to go to your mbox
that should get you good for midi cables....
on the mpc, everytime you want to record a track using instruments from your mpc you will need to set a new track. on the main screen you would go to a new track (where Tr:01-Track-01 is) and change S:DRUM1 to S:MIDI, then to the right of that where it says OFF, turn that to 1A-Device01 ... you will have to make a new track for each instrument you use to help when bouncing tracks to mbox. for instance 1A-Device01 is the 1st track on your triton, 2A-Device02 is your second track and so on. make sure you also make a new track each time for where Tr:01-Track-01 is also for each instrument.
for the mbox i might be a little rusty on this so im going to post a quote from another site....
"in Pro Tools, go to setup - midi - midi studio. this is where you tell pro tools where your midi devices are connected. next, go to setup - midi - midi beat clock. you want to 'enable midi beat clock' and select the devices that are going to be receiving midi beat clock. all devices that you setup under midi studio should be showing. next, set pro tools' tempo for the session if you haven't already. This setup is based on Pro Tools being the MASTER device and the other device(s) SLAVE(S). Make sure that on your hardware/midi interface that the midi output is going to the midi input on the slave devices. On the mpc, press mode, then pad 9 and go to the sync tab. Choose "slave" under "sync in" and the port, 1 or 2, that your mpc will receive midi input. That's it!! When you start Pro Tools' sequencer, the mpc should start too at the same bar/beat location. I've tried slaving Pro Tools to the MPC1000 and Fantom Xa on diff. occasions but I could never get them in sync with Pro Tools. Tried diff. framerates and settings, but still, no luck. So I prefer using Pro Tools as the MASTER sending midi beat clock. Another thing, make sure that whatever you're tracking into Pro Tools doesn't change tempo during the song. If so, you'll have to edit tempo events in the tempo ruler. Hope this helps!!"
let me know if you need any more help.
Feb 16, 2009 | Akai MPC-4000 Plus Production Center (w/80...
I have a triton LE Korg workstation. I have the MIDI interface cables from Yamaha. I would like to record straight to my computer using these cables. Is this possible?
Hi
Yes it is possible if you have a MIDI breakout lead. This lead plugs into the game port on the back of your sound card(if you have one) If you do not have a game port, then you will need a midi interface that can be plugged into your PC via USB port. USB Midi interfaces can be bought from most music shops.
What does the lead that you have look like? If it has a 180 deg 5 pin DIN plug at each end then you have a standard midi connection cable. Useful only for plugging into the MIDI interface I just mentioned. If you have any questions about this,I am happy to help you out. A "FixYa" rating would be great for my advice and future efforts to help you resolve this:)
regard
Graeme
Mar 15, 2008 | Audio Players & Recorders
Korg triton le worstation 61 keys
Have a look through this lot; http://www.korg.com/service/support.asp?A_PROD_NO=TRITONLE Hopefully what you need is in there - please ask again if not :)
Jun 28, 2007 | Korg Legacy Collection
Computers & Internet Logo
238 people viewed this question
Top Korg Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
ray gallant
ray gallant
Are you a Korg Computer and Internet Expert? Answer questions, earn points and help others
