SOURCE: m mod n in Casio fx991MS
there is one button ab/c beneath CALC... if u want to calculate 7 mod 4 then... u should press 7 then ab/c 4 and equal to
1, 3 ,4 which is 4*1=4 and 7-4=3 remainder...
SOURCE: casio FX-9750G Plus won't turn on
I had the same problem too. I just bought it and I was trying to turn it on but it wouldn't though the manual said that it was supposed to automatically when the tab was pulled out. Good news: the Reset button on the back works. I pushed it for some time with the end of a toothpick and it worked.
hope it helps.
SOURCE: how can i use Graphic
Here is enough to get you started and a little more.
Read the post ant consult your calculator manual. The screen captures below may not look exactly as your calculator but the steps are identical.
A. Define a matrix (Create it)
At the bottom of the screen you have 3 menus for Row and column manipulations. But those will have to wait for now.
Press [SHIFT][QUIT] to return to the list of matrices to create new ones
B Operations on matrices
Once
you have one matrix, you can do operations on it: Calculate the
determinant (if matrix is square), calculate its inverse, transpose,
augment it, fill it, etc..
Example : calculate the determinant of a matrix A (already defined).
C. Square of Matrix A
[OPTN][F2:MAT] (MAT) [Alpha] A ^2 [EXE]
D. Product of two compatible matrices MatAXMatB
[OPTN][F2:MAT] (MAT) [Alpha] A [*] (MAT) [ALPHA] B [EXE]
Part E Invert a (square, non singular) matrix that was already defined.
Press [OPTN] [F2:Mat] to open a screen similar to the one in capture above
Press [F1:Mat] to have identifier Mat displayed.
Enter the name of the matrix by pressing [ALPHA] A, for example.
Press [SHIFT] [ ) ] activate the (x^-1) key.
This is what you might see (with parentheses and without).
Press [EXE] button to calculate the inverse.
Testimonial: "Thanks. The answer about (how to solve the matrix using graphic calculator) you sent to me is very helpful. Thanks again"
SOURCE: how do I calculate the
It seemed there is no Modulo function in fx-100MS. But Mod is just the remainder of a division operator.
So if you have A mod B = C, divide A by B, subract the remaining whole number, and multiply it by B to get C.
Example:
7 mod 4 = 3
In the Calculator:
7 / 4 = 1.75, then 1.75 - 1 = 0.75. Then 0.75 x 4 = 3
SOURCE: A mod B in Casio
It's a bit convoluted, and it only works for integers, but here's one way. Press MODE 4 to switch to BASE-N (integer) mode. If the screen doesn't read "Dec" then press the x^2 key. Now, to calculate m mod n, calculate m-m/n*n. No shortcuts, no rearranging. That's m minus m divided by n times n. You have to enter both numbers twice, but you will get the modulus.
Press MODE 1 to return to your previously scheduled calculations.
