Sewing Machines Logo
A
Anonymous Posted on May 26, 2017
New Home Type F threading bobbin take up
I bought this at an estate sale and It was threaded except for the needle. The bobbin thread will not pick up. I am not sure i have it threaded on the bottom correctly. Do you have a manual or a diagram of how the bobbin should be thread in the machine to get the needle thread to pick it up. This is an electric machine. I can not find the serial number on the machine but the Westinghouse motor says style 172254-A NP 45306.Thank you for your help. Claudia Meyers email @ [email protected]
R.A. Ellis
Level 3:
  • New Home Master 12,731 Answers
  • Posted on May 26, 2017
R.A. Ellis
New Home Master
Level 3:
Answers
12731
Questions
Helped
2613642
Points
59176
Perhaps one of these will help:
New Home Model 532 Sewing Machine Threading Diagram
New Home Model 2022 Machine Threading Diagram
Thread Bobbin on Newhome Sewing Machine
HINT: install a brand new needle. Remove the top thread from the machine. ALWAYS RAISE the presser foot and then rethread the top thread. The upper tension should start out set at the midway point. Use only fresh, good quality thread--AVOID old or bargain bin threads.
If the machine is threaded correctly top and bottom, but is still not catching the bobbin thread, then it's possible the machine is out of time. Search for sewing machine timing or take it for service.
Since it is an older mechanical machine, it is recommended to clean and oil the machine frequently. Oil Before using it if it has been in storage. If the machine is sticky, motor drags, etc., here's a good reference for getting it back in shape:
Wheel on right side that controls the needle up and down is very tight...
5 Related Answers
Anonymous
  • 5 Answers
  • Posted on May 29, 2007
SOURCE: needle will not pick up the bobbin thread
www.whitesewing.com try there web site
Anonymous
  • 3 Answers
  • Posted on Aug 16, 2007
SOURCE: needle picks up bobbin thread but then thread gets stuck
I've had similar problems (as well as other problem with the thread breaking all the time and the "shuttle race" thing that holds the bobbin falling out. One very important thing that isn't mentioned in the manual but that the salesman stressed is that you have to use only "Schmetz" brand needles. They are a tiny bit longer, but that makes all the difference in the world if your stitches are skipping. I forgot and used Singer needles and had horrible results.
sewtexas
  • 136 Answers
  • Posted on Jul 04, 2009
SOURCE: will not pick up bobbin thread
Unusual for this machine. Check to be sure the needle is inserted with the flat side to the back of the machine. If it is, remove the needle plate, bobbin and bobbin case. Turn the hand wheel slowly toward you and see if the point of the hook is above or below the eye of the needle when the hook point is aligned behind the needle. If the eye is above the point of the hook the machine is out of time and best taken to qualified technician.
Anonymous
  • 208 Answers
  • Posted on Jan 16, 2010
SOURCE: needle not picking up bottom thread
Remove the needle plate and the bobbin case.
Ensure that the needle is inserted all the way up into the needle clamp.
Set the machine for straight stitch, center needle position.
Slowly turn the handwheel in the normal sewing direction and observe the following hook timing setting:
When the needle reaches it's lowest point and travels up 3.5mm, the point of the hook should be directly behind the needle, or at least within 1 or 2mm.
Another view is as the hook passes the needle, it should pass the needle slightly above the eye of the needle.
If the timing looks good, use some alcohol on a bit of cloth to clean the hook, careful around the tip of the hook as it is very sharp.
If the hook timing is off, you will need to take it to a knowledgeable service person as there are several possible solutions and several other related adjustments which will need to be made.
Anonymous
  • 23 Answers
  • Posted on Apr 13, 2010
SOURCE: Bobbin thread comes out in a mass of threads
ENSURE you have threaded the bobbin properly and at the right tension. Also, ensure that you have routed the bobbin thread properly in the bobbin case.
2answers
I changed my bobbin thread and now my machine won't pickup the bobbin thread. I've changed spool of thread, bobbin and cleaned but still won't pick up the tread.Brothers model LS-2125
HI Elizabeth.
Found this on the internet.
There could be several things that could cause the machine not to pick up the bobbin thread.
  • The upper thread could be tangled.
    Remove the thread completely from the machine.
    The correct size spool cap should be used for the size of the thread spool.
    Re-thread the machine according to the directions in the manual.
One Point Advice Place a spool of thread on a spool pin.
One Point Advice Upper threading
  • Remove the bobbin and make sure the bobbin is threaded properly in the shuttle race.
    Remove any loose threads or lint in the shuttle race.
One Point Advice Installing a bobbin into a bobbin case
  • You could be holding the needle thread too tight.
    Hold the thread lightly to keep the end from going down into the shuttle.
  • The needle could be thread incorrectly.
    Thread the needle eye from the front to the back.
  • The needle could be bent or improperly inserted.
    Install a new needle with the flat side of the needle facing the back.
  • if this does not help you go to this link.
won pickup the bobbin thread Google Search
2helpful
Repairing bobbin thread uptake
Make sure you are using a brand new needle. Bent/dull/damaged needles sometimes will not connect with bobbin thread.
If it still does not pick up the bobbin thread, then it most likely is a timing issue (the needle arrives at the wrong time to intercept the bobbin thread). There are web sites and videos online that discuss sewing machine timing. Or you can take it for service.
Repair manuals are difficult to find as they were issued only to repair service personnel. Sometimes you may find one for sale or even uploaded, but that is rare.
My Ruby Viking will not pick up bobbin thread
Install a brand new needle. A bent/damaged needle sometimes will not pick up the bobbin thread.
Verify the machine is threaded correctly.
If it still will not pick up the bobbin thread, most likely it is a needle/hook timing issues. There are many web sites and videos online explaining sewing machine timing. Or take it for service.
When thread cotton. Cotton don't pick up bobbin cotton please help bernette65
Be sure to use a brand new needle. A bent/damaged needle may have difficulty picking up the bobbin thread.
Verify that both upper and bobbin threads are threaded correctly. If so, and it still fails to pick up the bobbin thread, most likely there is needle/hook timing issue. Take it for service.
2answers
Why won't my new home super stretch stitch model-844 pick up bobbin thread to sew manual book
If you need a manual, search the internet for:
Make + Model + the word "Manual"
or contact the manufacturer.
Try installing a brand new needle. A bent needle sometimes will not connect properly. Be sure that both upper and bobbin threads are threaded correctly.
On the other hand, the needle/hook could be out of time. You can check that by hand turning the handwheel and watching the needle/hook movement. There are a multitude of web sites and videos that discuss timing. Or--check with a sewing machine technician.
My needle won't grab the bobbin thread but if I put some fabric in and start to sew the bobbin thread comes through. However, the bottom thread is all bunched up and causes the machine to jam.
the looping on the underside sounds like a needle thread tension problem. 1st off check top (needle) threading then turn machine by hand to pick up bobbin thread
Please put on correct size needle. And check the tension & timings.
Top New Home Sewing Machines Experts
NOEL
NOEL
Paul Bade
Are you a New Home Sewing Machine Expert? Answer questions, earn points and help others
