Hi Christine,
Please check details below:
1. First check if the software provided with your Printer is already installed and if not check the URL below to download the software or driver just in case you lost your Canon CD/DVD: http://www.canon.com.au/For-You/Printers/PIXMA-InkJet-Printers/MG3260
2 Once installed and for Windows user follow the steps below:
a. Click "Start" then click "All Programs"
b. Look for for "Canon Utilities" and click "MP Navigator EX 3.0".
c. Choose "One Click" on the upper right.
d. Then you can start scanning starting from "Auto scan", "Save to PC", "Save as PDF file" and so on.
For sample Video instructions, please check the youtube link below:
http://www.youtube.com/watch?v=qg_4FDAFjN0
Please note that I'm currenly im using Canon Pixma 250.
Hope this will help.
Best Regards,
Art
Also the One-Click Screen below:
SOURCE: Can't find my manual and
Your printer must be turned on.
Open the printer by lifting the whole scanner assembly. The Carraiges should move into position so that the cartridges can be inserted.
SOURCE: i have purchased this canon
Once you re installed whole software ......... and install one by one softwares frm CD...... and go to control panal and change the settings ther.............
and restart you system .
Hope this will help you out
SOURCE: I am trying to connect
Easy fix! Go to Canon's website support for your printer here
Enjoy!
I’m happy to help further over the phone at https://www.6ya.com/expert/susan_42b401e0b1603d8a
SOURCE: I can't get the scan
Go to Control panel = Uninstall program = remove Canon Mp470 driver... after completing = re-install the programme again.. while installing program you must select "Easy install" thanks...
SOURCE: I need to scan something
what operating system (OS) are you using on your machine? is it windows xp/vista/windows7?
1. try installing the software CD that came with the printer.
2. after installing it go to start button and select devices and printers. and add the printer from.
after this it should work perfectly.
To "Settings/Registration Table"
You can specify the method for restarting scanning of documents when a paper jam occurs in the feeder.
For information on the optional products required to use this function, see "Optional Products Required for Each Function."
Details of each item are shown below.
[From 1st Page]:
If a paper jam occurs in the feeder, scanning starts again from the first page of the document.
[From Stopped Original]:
If a paper jam occurs in the feeder, scanning starts again from the page of the document scanning was interrupted.
