THE SCANNER DOSN'T SCAN ALL THE IMAGE IT GETS TO HALF WAY AND SAYS IT IS COMPLETED BUT ONLY HALF THE IMAGE SHOWS AND MOST OF THE TIME IT WONT SCAN AT ALL. HOW EVER YOU CAN PHOTO COPY SOME THING USING THE SAME SCANNER TRAY.
SOURCE: Officejet 5510 Scan Function disappeared
HP has a fix for the Internet Explorer 7 issue on it's download page. You can also install the full feature software for a newer model, I used the OfficeJet L7780 and I now have additional features plus it works in VISTA. Just be sure to select "WIRED/WIRELESS" when asked how to connect and select "CONNECT LATER" when prompted that the printer could not be found. Works great.
SOURCE: The scanner dont work in my HP officejet 5610 all in one
This is a known issue with HP printers. Do not worry, if you get this message that the scanning software could not be found the please go to the link
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=441125&lc=en&cc=us&dlc=en&submit.y=0&submit.x=0&lang=en&cc=us
Select the Operating System.
From the list select. ...
HP Full Feature Software and Drivers
Then scroll down to the 3rd option......
Click on Download only >> Save the file to the desktop.
Start installation and make sure that the Printer is not connected using the USB cable to the computer.
While installing, you will get the option to connect the printer. Do not connect the printer.
Select the option "I will connect it later". Go next the installation will be complete.
After the installation is complete...leave the CD inside the computer.
Connect the computer and the printer.
It will show you the configuration window.
Wait until you see the "Start using the device" option.
Click on "Start using the device".
You should see the solution center window now.
If it is succesfull. Try scanning using the Solution center.
If it is succesfull, you can now scan using the printer as well.
Try it and let me know if it works and please let me know your issue in detail.
SOURCE: hp scanner 3030
i have a hp 3030 all in one is there.. printer, xerox, fax is working properly but scan is not working .. kindly solv this problems..
SOURCE: Printing Photos on Photo Paper
Ensure u are placing the paper in the photo tray..
if u r printing from the memory card which is inserted in the printer..ensure that the PHOTO BUTTON on the printer is on..
You can also try to reset the printer by going to the SETTINGS/TOOLS menu (RENCH SYMBOL) and then look for the Factory Restore (Might be under "Preferences")
SOURCE: scanner error 12
uninstall the software of scanner and reinstall it
check your cables for loose contacts
