SOURCE: My Maytag dishwasher does not drain water after the wash cycle is over
Hi olabrk,
If you have a disposal make sure it is clear. You can put some icecubes in it to clean the blades and run some water through to make sure the drain is clear. If the dishwasher will still not pump out all the water check the drain line from the dishwasher to the sink drain for obstructions. If the drain is you will have to check the pump for obstructions. Sometimes glass, popcorn, toothpicks etc.... can get in the pump and prevent it from pumping out. If the pump is clear, then you will need a new pump. Good luck to you.
Mike Anderson
SOURCE: Maytag Jetclean Dishwasher EQ Plus, Model
You have debris down in the pump area. To get to the problem you will work from inside the dish washer and start by removing the spray arm and then using torx driver you will need to remove upper components of the pump/motro assembly to get to the debris. good luck
SOURCE: I need a replacement basket roller i.e., plastic
Try this part # AP4113585 at www.appliancehelponline.com
