Question about Baby Lock Sewing Machines
Walking Foot Trouble
I am quilting using a Baby Lock Elizabeth and a walking foot purchased from my Baby Lock dealer. I am able to attach the foot and sew without a problem, but then my presser foot and needle suddenly start jumping. The machine makes a popping or gun-shot like noise each time this happens. It only happens with the walking foot on. I've tried replacing the needle, re-threading, putting the presser foot on again, and sewing slower or faster. Nothing seems to be working. Any suggestions? Thank you!
  • Anonymous Mar 20, 2014
    it bumps and jumps
    Problem Solver:
  • 23 Answers
If possible try suggestions given and check needle position make sure its not hitting something Adjust if possible take in for servicing.
Posted on Jul 31, 2014
  • Baby Lock Master
  • 1,564 Answers
Sounds to me like you are getting what I call "flagging" of the material... where a tiny bur or something catches the material and pulls it up. If possible increase the presser a bit on the presser foot. You might also have the wrong foot for the machine or simply a defective one.
Also when it does this... do you notice any bobbin thread on top of the seam?
Posted on Feb 26, 2013
SOURCE:
  • 106 Answers
SOURCE: sewing with walking foot
Take the needle out and run the machine for a while with the walking foot fitted. Refit the needle and try again but only turn the machine over by hand to see if the problem has cleared. If no luck it sounds like the walking foot timing needs adjusting.
Posted on Apr 05, 2008
SOURCE: stitches
Usually a walking foot is for straight forward stitching only.It keeps the many layers from shifting for you. The "hand-look" quilting takes a couple stitches forward then one back. If you look close, you will see about every other stitch is thicker and stands out more.
Posted on Sep 23, 2008
SOURCE: skipped stitches and noises
sounds like there might be some threads caught between the tension discs. Try using a small strip of fabric to 'floss' between them. You might also have some thread caught in the hook assembly.
Posted on Mar 26, 2009
  • 1116 Answers
SOURCE: I have a singer 6202 sewing machine and I need to
You have to unscrew the presser foot, then attach the WF, using the same screw.
Make sure the lever on the WF rests on top of the needle bar clamp.
Some WF have a two prong lever and this fits around the needle clamp like a lobster claw.
Posted on May 22, 2010
  • 255 Answers
SOURCE: Using a walking foot on my Necchi 3537
Hi JoEllen,
The walking foot replaces the normal pressure foot on your machine. There is a screw on the left-hand side of the pressure shaft that holds the ankle (if your Necchi uses snap-on feet) on the shaft. Loosen this screw until the pressure foot (or the pressure foot/ankle combination) comes off. Now slip the walking foot on where the other foot came off and tighten that screw. You're ready to go!
Robbie
Posted on Jun 05, 2010
Can you use quilting bar with walying foot that came with si ger 9960
The info I found has no mention of the quilting bar for the Siinger 9960 walking foot. Most machine with that functionality include the quilting bar with the walking foot. There also needs to be a hole through the walking foot and a method to attach the bar to the foot which doesn't seem possible with what I located. However, you may be able to attach a bar or a guide of some sort using something like masking tape that can be used as a guide.
On a straight-line quilting tutorial I saw recently, the quilter laid down strips painter's tape to mark the lines on the quilt before doing any stitching. Then she simply stitched next to to painter's tape to get straight lines.
Feb 08, 2018 | Sewing Machines
When using the walking foot how does the guide work?
Yes, you would set the guide at the distance you want the next row to appear. Set the guide to follow the previous row and then stitch with the walking foot to create the new row.
How to quilt parallel straight lines using Walking Foot Quilting Tips...
Dec 05, 2016 | Sewing Machines
How do I attach the quilting bar to the walking foot on my Simplicity Quilters Classic? The manual doesn't show how to do it
There should be a hole across the back of the walking foot (penetrates the walking foot usually from right to left, although some feet will have 2 guides--one for left to right, the other left to right) where the bar mounts and a screw to tighten and hold it in place.
Quilting Bar Attachment
Oct 06, 2016 | Simplicity Quilter's Classic SW240...
Brother sewing machine LX 2500
Walking feet attach much the same way on most machines. They can be boogers the first couple of times. It helps to tilt the foot and guide it toward the needlebar from the side in order to get the fork (if your foot has a fork--some just have a bar that sets on top of the needleclamp screw) around the needleclamp screw. In cases of extreme frustration, I've removed the needleclamp screw and then reattached it once the foot is in place.
Just use patience. If frustrated, walk away. Whatever, do not force or bend the foot in order to install.
How do attach the walking foot Brother
How to use the Brother SA140 and SA188 Even Feed Walking Foot
How to Use the Brother SA107 Walking Foot
Attaching Walking Foot
How to attach walking foot to your sewing machine Elizabeth Ruffing Art...
Problems installing my walking foot
Jun 07, 2016 | Brother Sewing Machines
Which foot do I use for quilting
a quilting foot or buy one with a round hole in it great
Mar 09, 2015 | Sewing Machines
I have just started learning how to quilt and I was told I needed a walking foot to quilt the sandwich together. I purchased one today, but I don't even know how to attach the foot. I also need to...
The foot is attached as normal, but when you're attaching it, the fork-shaped part that sticks out of the right-hand-side has to be hooked around the round pillar sticking out horizontally from the right-hand-side of the needle bar and that holds the needle securing screw. When the foot is down, you will see that the upwards motion of the needle bar raises the upper set of feed dogs on the walking foot - the whole purpose of the walking foot is to provide, effectively, a set of feed dogs on the top of the material as well as the toothed ones below the stitch plate - this allows multilayered or thick materials to be sewn as when doing quilting.
Jun 30, 2011 | Bernina Activa 130
How to attach a quilt guide
You have to unscrew the screw for the presser foot first. The walking foot will then fit. Use the same screw to attach the walking foot. Before you insert the screw, take the white handle on the walking foot and slide it on the screw arm for the needle. Now tighten the screw.
Mar 21, 2010 | Singer Sewing Machines
I hav e Bernina 1150. When I attach the walking
Hi, when you quilt straight lines using the walking foot, you need the feed dogs up, to move the fabric in a straight direction under the needle. When you do free motion quilting, which is done with a darning foot, your hands move the fabric in many different directions. Since you want to be the one to move the fabric, you put the feed dogs down and you do the work. So when you use the walking foot, keep your feed dogs up. When you use the darning foot, feed dogs down.
Feb 20, 2010 | Sewing Machines
Stitches
Jul 25, 2008 | Brother CS6000i Computerized Sewing...
Sewing Machines Logo
188 people viewed this question
Top Baby Lock Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Thomas F. Schneider
Are you a Baby Lock Sewing Machine Expert? Answer questions, earn points and help others
