I lift the presser foot and when I let go of the lifter the foot won't fall back down..will come down if you gently pull it
SOURCE: I live in Ecuador. I
Good day!!!
If your screen stated"main motor blocked" then I suggest you remove the thread,both the top and the bottom.Please change the needle too.but If the problem is unsolved,kindly loosen or unscrew the casing which is in the front of the bobbin, then look/find anything
that might be obstructing the bobbin. check again the thread, bobbin and needle.Also for the last thing put an oil to the parts which you think it needs it like the moving parts re-start or reboot it then leave for a whole night.
Thank you and good luck...
SOURCE: Model 6230- presser foot lifter won't move presser foot
That's the problem seized up use a penetrating oil from the top and work it up and down and it should free up
