Need to delete the photos, but do not have a phone password and therefore does not delete the photos A1203
SOURCE: Deleting photos
-Go to Menu
-select Get It Now (the arrow icon on the left)
-select option 3, Get Pix
-Select option 2, Pix Gallery
-Once a pic is highlighted, select Options and then 7 to Erase
SOURCE: Transfer "assigned media" to Micro SD
YOU CAN DO THIS BY MOVING YOUR FILES FROM YOUR MOBILE TO YOUR MEM CARD. THIS FUNCTION IS AVAILABLE IN YOUR MODEL.
IF YOU CANT DO SO. JUST TRANSFER THIS FILES TO YOUR COMPUTER VIA A DATA CABLE AND THEN TRANSFER THE SAME FILES FROM COMPUTER TO MEMCARD USING A MEMORY CARD READER.
HOPE THIS WILL HELPS U.
PLS. RATE MY SOLUTION.
NICE DAY
KETAN
SOURCE: I cannot delete photos from my n97, there are 127
Use the Nokia Photos application on your PC. Connect your phone to the PC using for example USB cable. In the left top corner of the application the name of your phone should appear. Click on it - it will turn green. Now you will see the photos on your phone. Select the icons that you want to delete and press delete (on the keyboard).
SOURCE: DELETED PHOTO
You may try asoftech photo recovery which helped me before. You can download trial for free
http://www.asoftech.com/apr/
Please be noted that your phone memory should show as a drive letter in your explorer, if not, you need to take out your memory card and connect using a card reader, or plug-in to card reader slot if there's any on your computer.
SOURCE: Recovering deleted files
You may try mobile phone data recovery software, recommended asoftech data recovery which helped me before. You can download trial for free
http://www.asoftech.com/adr/
