I have forgotten my nokia c5-03 factory reset code.Is there any method by which the code can be breaken.
SOURCE: How to reset lock code on nokia c5-03?
- To unlock you Nokia C503 (if forgot or lost lock code) you can unlock it using a master code. - To get the master code i need the IMEI code of your mobile phone. - With the help of this IMEI code we can get the master code of your mobile and unlock the mobile and reset it with a new password.
- The IMEI number can usually be found on the sticker underneath the battery or by typing *#06# into the phone keypad.
Hope this helps, please rate and leave a comment if the solution was helpful, thanks!
SOURCE: reset my nokia E71 security code? i have forgotten my code
The default Security code for Nokia is 12345 unless you have changed it. If you have changed it you will have take it to a repair or service shop where they will be able to retrieve it using a software.
SOURCE: how to reset nokia 2630 to factory default
MY NOKIA 2630 IS JUST SUDDENLY ASKING FOR A SECURITY CODE & I HAVE NEVER HAD A SECURITY CODE
SOURCE: nokia 3110c keypad lock forgotten
if you could get to settings menu and restore factory settings,your problem will be solved
