SOURCE: When I change the temp. setting it keeps heating at original temp
The keypad appears to working correctly.
When you alter the set temperature via the keypad the display will flash the temperature thats to be acheived, once it stops flashing the keypad will revert back to the current temperature of the water.
Hope that helps,
Ian.
http://hottub.synthasite.com
SOURCE: just installed new heater - error code sns -
Assuming that there are no air-locks and the pump is running ok....
Check the sensor connections on the PCB and make sure that they're clean and secure.
If the fault persists, (with the power turned off) you will need to remove the sensor connections and test the resistance of the sensors with an ohm meter. They should read the same. If they're different you will need to replace them.
Regards,
Ian.
SOURCE: I have the Balboa 500Z pump heater kit. Its hooked
I have a 6 month old Balboa 500Z. I have noticed that the filter system tis running all the time 24/7. I have reset the filter cycle to run for 2 hours { F2 }. It still is running all the time. It dose not seem to make a difference what I set the cycle for it just keeps running
SOURCE: I have a balboa spa
It is possible that the board is bad. A loose connection orlow voltage issue may also cause this problem to occur. If the voltages arewithin the acceptable rand and all connection are tight then remove any accessoryequipment and restart the unit to see if the problem continues. If it does thena new board will probably resolve the issue.
You can find answers to common spa problems online at http://www.balboadirect.com/support.aspx
Hope that helps!
