Refrigerators Logo
A
Anonymous Posted on Feb 25, 2013
TPS24BPDABS HAS A CONTROL PROBLEM - GE Profile Performance 29.8 cu. ft. Side-by-Side Refrigerator with Dispenser TFX30PPBWW
1helpful
Missing variable control voltage on the blower fan control module on a 2008 Buick lucerne
What are you using to test this control signal ? Were you on right wire ?
Blower Motor Control Processor The blower motor control processor is an interface between the HVAC control module and the blower motor. The blower motor speed control, battery positive voltage and ground circuits enable the control processor to operate. The HVAC control module provides a pulse width modulation (PWM) signal to the control processor in order to command the blower motor speed. The processor supplies 12 volts to the blower motor through the blower motor voltage supply circuit. The control processor uses the blower motor ground as a low side control to adjust the blower motor speed.
Chevy Trailblazer EXT Blower Motor Won Turn Off The blower motor in this video don't shut off , but he show's how to test the PWM signal right !
Your blower motor control module is probably bad , or HVAC control panel is bad , or a wiring problem !
2helpful
2answers
What is an ICP - RCC - Speedometer fuse for on a 1997 ford taurus dohc ICP - RCC?
Hey Brian ,
ICP - Integrated control panel
RCC - Remote Climate Control Module
Integrated Control Panel-Electronic Automatic Temperature Control
Control Assembly The Taurus, Sable vehicles group together the following systems into a single integrated control panel:
  • AM/FM stereo radio
  • clock
  • rear window defroster switch
  • electronic automatic temperature control (EATC)
  • full-logic cassette tape player
  • compact disc player control (optional)
The remote climate control module is mounted to the A/C evaporator housing behind the integrated control panel. The integrated control panel is connected to the remote climate control module with a dedicated two-wire communication link. The integrated control panel EATC features:
  • a vacuum fluorescent display (VFD) for displaying set temperature, ambient temperature, function and diagnostic trouble codes (DTCs).
  • electro-luminescent backlighting for all buttons and graphics.
  • function override buttons.
  • temperature control and blower speed rocker switches.
CONTROL LOCK GE GAS DRYER
  1. Press and hold for 3 seconds the "Control Lock/Unlock" button on the control panel to lock the control panel.
  2. Listen for a double beep and observe the "Control Lock" status light is lit when the control lock is in effect.
  3. Press and hold for 3 seconds the "Control Lock/Unlock" button on the control panel to unlock the control panel. The "Control Lock" status light is goes out when the control panel is unlocked.
Jan 31, 2015 • GE Dryers
1helpful
Fuse Box Diagrams (Inside and Engine) for 2009 Volkswagen Tigua?
Attached are the diagrams requested - good luck!
Fascia 1
Fuse, (Amps), Circuit
F1 -
F2 -
F3 -
F4 -
F5 -
F6 -
F7 -
F8 -
F9 (5A) Supplementary restraint system (SRS) control module
F10 (10A) Four wheel drive control module
F11 (5A) Parking aid control module, self-parking system control module
F12 (10A) Gas discharge headlamp control module (LH)
F13 (5A)
ABS/ESP system, AC system, anti-dazzle interior mirror, heated windscreen washer jets, seat occupation control
module, transmission control module (TCM), reversing lamps, engine management system
F14 (10A)
ABS control module, engine control module (ECM), heated seats, power steering control module, suspension
control module, trailer control module, AC control module, instrumentation control module, CAN data bus
gateway control module
F15 (10A)
Auxiliary heater, data link connector (DLC), parking brake control module, engine management, headlamp
direction control module
F16 (10A) Gas discharge headlamp control module (RH)
F17 (5A) Instrument panel
F18 (10A) Mobile telephone control module, multimedia control module
F19 (10A) Steering column function control module 2
F20 (5A) ABS control module, AC system, transmission control module (TCM)
F21 (15A) Door function control module, left rear, door function control module, right rear, multifunction control module 2
F22 (5A) Alarm system, multifunction control module 2
F23 (10A) ABS/ESP system, AC system, data link connector (DLC), rear view camera control module, headlamp switch
F24 (10A) Door function control module, driver, door function control module, passenger
F25 (20A) Transmission control module (TCM)
F26 -
F27 -
F28 (40A) AC control module, auxiliary heater
F29 (15A) Rear screen wiper motor
F30 -
F31 (20A) Auxiliary power sockets, cigarette lighter
F32 -
F33 -
F34 -
F35 -
F36 -
F37 -
F38 (10A) Steering column function control module 1
F39 (20A) Headlamp washers
F40 (15A) Trailer control module
F41 (15A) Trailer control module
F42 (20A) Trailer control module
F43 (25A) Sunroof control module
F44 (25A) Parking brake control module
F45 (25A) Heater blower motor, heated rear window
F46 (30A) Door function control module, driver, door function control module, passenger
F47 (30A) Door function control module, driver, door function control module, right rear
F48 (15A) Fuel pump (FP)
F49 (20A) multifunction control module 2
F50 (25A) Parking brake control module
F51 (40A) AC/heater blower motor control module
F52 (30A) Seat heater control module
F53
(20A/30A)
Headlamp washers
F54 (30A) Auxiliary power sockets
F55 (15A) Lumbar support adjustment
F56 (15A) Suspension control module
F57 (25A) Sun blind control module
F58 (1A) Trailer warning lamp
F59 (20A) Multimedia control module
F60 -
Fascia 3
in engine bay
Fuse (Amps) Circuit
F1 -
F2 -
F3 (5A) Multifunction control module 2
F4 (30A) ABS/ESP system
F5 -
F6 (5A) Instrumentation control module, steering column function control module 2
F7 (40A) Ignition main circuits
F8 (25A) In-car entertainment (ICE)
F8 (25A) Voltage converter
F9 (5A) Mobile telephone control module
F10 (5A/10A) Engine control module (ECM)
F11 (20A) Auxiliary heater control module
F12 (5A) CAN data bus gateway control module
F13 (15A/30A) Engine control module (ECM)
F14 (5A) Engine management system
F15 (5A/10A/15A) Fuel pump (FP), AC compressor clutch, engine management system
F16 (30A) Multifunction control module 2
F17 (15A) Alarm system horn
F18 (30A) Audio system
F19 (30A) Windscreen wiper motor
F20 (10A) Engine management system
F21 (10A/20A) Engine management system, fuel pump (FP) control module
F22 (5A) Clutch pedal position (CPP) switch
F23 (10A) Engine management system
F24 (10A) Engine coolant blower motor control module, engine management system, engine coolant heater
F25 (40A) ABS/ESP system
F26 (30A) Multifunction control module 2
F27 -
F28 (50A) Glow plug control module
F29 (50A) Electric seats
F30 (50A) Ignition switch circuits
Location Component
1 Petrol: Engine control (EC) relay 1
1 Diesel: Ignition main circuits relay
2 Petrol: Engine control (EC) relay 2
2 Diesel: Engine control (EC) relay
Code p1443
without knowing your make or model:
  • p1443
    Evaporative Emission Control System Control Valve
  • audi
    EGR Valve Position Sensor Signal Too Low
  • bmw
    Leakage Diagnostic Pump Control Circuit Signal High
  • ford
    EVAP Control System Purge Control Solenoid or Purge Control Valve Fault
  • hyundi
    EVAP System Tank Cap Missing
  • infinity
  • lexus
    Secondary Air Injection Vacuum Switching Valve Circuit Malfunction Bank 2
  • mazda
    Evaporative Emission Control System Large leak detected
  • mitsubishi
    EVAP Purge Control Valve 2 Circuit Malfunction
  • nissan
  • suburu
    Evaporative Emission Control System Vent Control Function Problem
  • suzuki
    EVAP Purge Control Valve Malfunction- Stuck Open
  • toyota
  • volkswagon
  • 1helpful
    What is code F-24
    E11 Fill time too long. Refer to test (1).
    E13 Water leak in tub or air leak in air bell. Refer to test (2).
    E21 Water not pumping out fast enough. Refer to test (3).
    E23 Drain pump relay on control board failed, wire off pump or pump Replace console control board, wire or
    defective. pump.
    E24 Drain pump relay on control board failed. Replace console control board.
    E31 Pressure sensor not communicating with control board. Refer to test (4).
    E35 Pressure sensor indicates water overfill. Refer to test (5).
    E36 Console control board problem. Replace console control board.
    E38 Air chamber clogged or pressure sensor defective. Check air chamber, rpl press. sensor.
    E41 Control board thinks the door switch is open. Refer to test (6).
    E43 Console control board thinks the door locking device has failed. Refer to test (7).
    E44 Console control board problem. Replace console control board.
    E45 Console control board problem. Replace console control board.
    E46 Console control board problem. Replace console control board.
    E47 Console control board thinks the door PTC circuit is open in spin. Refer to test (7).
    E48 Console control board thinks the door PTC circuit is closed. Refer to test (7).
    E52 Bad signal from tacho generator. Refer to test (8).
    E56 High motor current. Refer to test (9).
    E57 High current on inverter. Refer to test (9).
    E58 High current on motor phase. Refer to test (9).
    E59 No tacho signal for 3 seconds. Refer to test (10).
    E5A High temperature on heat sink caused by overloading. Test first-if bad-rpl speed control brd.
    E5B High temperature on heat sink. Replace speed control board.
    E5C High temperature on heat sink. Replace speed control board.
    E5D Communication problem. Refer to test (11).
    E5E Communication problem. Refer to test (11).
    E5F Communication problem. Refer to test (11).
    E66 Heating element relay failure. Refer to test (14).
    E67 Input voltage on microprocessor incorrect. Refer to test (15).
    E68 Current leakage to ground on heater or fuse opened. Refer to test (14 & 15).
    E71 Wash NTC failure. Refer to test (15).
    E74 Wash temperature does not increase. Wire off NTC - rpl water valve.
    E75 Water temperature sensor circuit. Refer to test (12).
    E82 Console control board problem. Replace console control board.
    E83 Console control board problem. Replace console control board.
    E91 Comunnication error between UI board and console control board. Refer to test (16).
    E93 Console control board problem. Replace console control board.
    E94 Console control board problem. Replace console control board.
    E95 Communication error. Replace console control board.
    E97 Console control board problem. Replace console control board.
    E98 Console control board problem. Replace console control board.
    EB1 Incoming power frequency out of limits. Refer to test (13).
    EB2 Incoming line voltage above 130 VAC. Check voltage at outlet. If < 130VAC,
    replace the console control board.
    EB3 Incoming line voltage below 90 VAC. Check voltage at outlet. If > 90VAC,
    EBE Console control board problem. Replace console control board.
    EBF Console control board problem. Replace console control board.
    EF1 Clogged drain pump. Unclog the drain pump.
    EF2 Too much soap. Advise customer to reduce the amount
    of soap they are using.
    TRACTION CONTROL.
    that is what it is desgined to do - reduce acceleration and apply the brakes intermittently when the wheels spin. You have a switch you cn push to disable it. You need to disable each time you start car. See owner manual.
    06-10: Traction Control 1996 Contour, Mystique Workshop Manual
    DESCRIPTION AND OPERATION Traction Control System The optional traction control system is designed to control wheel spin when accelerating on slippery or loose surfaces. Traction control system is available only with anti-lock brakes. The traction control system includes the following components:
    • Hydraulic control unit.
    • Throttle control actuator (9N825).
    • Traction control switch.
    • Traction control warning indicator.
    • Front brake anti-lock sensor (2C204).
    • Rear brake anti-lock sensor (2C190).
    The traction control system operates as follows:
    • System functions by transferring torque from the spinning wheel to the wheel with the most traction.
    • This is achieved by applying the brake at the spinning wheel through the hydraulic control unit or reducing the throttle opening.
    • Traction control braking and throttle control occur at vehicle speeds up to 50 km/h (30 mph).
    • At vehicle speeds above 50 km/h (30 mph), only throttle limiting control is used.
    • If speed control is operating when traction control system engages the traction control system will disengage speed control through the use of a speed control relay. This action is the same as applying the brake pedal with speed control engaged.
    1996 contour
    Traction Control Switch The traction control switch is located on the instrument panel, left of the steering column.
    1helpful
    Jenn-Air JDS9860AAP Control Panel Problem
    Control Panel
    1. Remove power from unit.
    2. Remove burner switch control knobs.
    3. Open oven door and remove screws securing control
    panel.
    4. Remove screws located on the right and left sides of
    the control panel.
    5. Grasp control panel on the far left and right sides and
    gently pull the control panel out and down.
    NOTE: Gently pull control panel out and down.
    6. Remove infinite switch control knobs, infinite
    switches, indicator lights, rocker switches, and
    electronic control/clock (as necessary) and transfer to
    the new control panel.
    7. Reverse procedure to reinstall control panel.
    Electronic Control
    1. Remove control panel, see “Control Panel”
    procedure, steps 1 through 5.
    2. Remove screws securing electronic control bracket to
    control panel.
    3. Label and disconnect terminal wiring from electronic
    control.
    4. Reverse procedure to reinstall electronic control.try that
    Jan 16, 2008 • Ovens
    Top Refrigerators Experts
    vince
    Johnny 1000
