I bought a 1 gb micro sd memory card and my phone cant detect it but sometimes it does but then again it wont detect it until now.. plz help...
Hi, i got the same problem and got to solve it. Try this...
1. the battery cover must be put on otherwise, the hp won't detect the memory.
2. try to fix the cover or hook by bending it.
Good Luck.!
I've got the same prob, did the tapeing it up wiv tape work? i was thinking of ways to fix it, an i relaized the sides were loose, does it work?
Replaced 250mb card supplied with a 2gb micro, now have same problem as you!
It's a new phone and the 250mb card supplied works fine.
Cover is fine.
I have the same problem.I used scotch tape to tape the cover with the sides.I'm changing phone ASAP.DO NOT BUY NOKIA 6500SLIDE FOR ALL GOING TO GET IT.
same problem of detecting memory card
it wont detect at all =[
even my 6500s does not detect memory card every now and then ? whatcould be the reason ? the phone remains on if we carefully remove theback cover but should the memory card not accessible after removingcover ??
