MTX JackHammer JH600 Car Audio Amplifier Logo
A
Anonymous Posted on Feb 24, 2013
Amp inside electrical problems mtx
Amp wont come on
My mtx ts5510 stopped working while driving. Was hooked to an mtx thunder 81000 class d and its still working. ????
Inspect speaker for loose wires/broken wires. Check inside box for loose connection. Blown fuse on amp. Ive literally pulled the wires out of the speaker. The little mesh ones from the terminal to the cone. Look for that. If you do find something broken or bad. remember you can call MTX and fix for a flat rate on most evrything they carry. Ive sent several amps there. normally around $100
Hi i have a mtx jackhammer JH202 amp and a mtx jackhammer jJH5510D sub and every so often when a song is playing there will be bass and al of a sudden it will shut off and after a few minutes it will come...
The problem was caused by you trying to run a 2OHM load on an amplifier which is designed to run only on 4OHM when it is bridged, the amplifier is most definatley cooked. An authorized MTX technician should take a look at it, to determine just how wide spread the damage is.
dreamsystems.
My mtx 1000xd will turn on but makes a sound inside near the circle donut looking with(lots of wires soldered) and where my ground is to the trunk bolt and even in side speakers. It will not power my...
sounds like you may have a bad torroid (the donut looking thing). you may also have a bad ground connection. make sure you have completely bare metal where the ground connection is. you need a very clean connection.
Has mtx stop selling the mtx ta81001?
Hello t3h_b,
The MTX web site shows the amp as a current product.
http://www.hifisoundconnection.com/ sells the amp and claims to have it in stock. However, MTX lists only 2 authorized online resellers:
www.crutchfield.com and www.sonicelectronix.com
Crutchfield doesn't list the amp at all and SonicElectronix shows it as "discontinued". I'd recommend going to MTX's contact page and ask them directly. They'll usually respond within a day or two.
Hope this helps.
I LIKE TO HAVE SOME ONE TO FIX MY AMP.
you have to send it to mtx. Most repair shops wont touch it. You can call mtx i had the same amp. It cost about 85 bucks plus shipping. the 85 bucks covered return shipping also.go to there web site it has the info for tech support and repair issue there. hope this helps
3helpful
3answers
Mtx TC-6001 Amps Problem
I had same problem with a TC6001 and get solution from MTX, not send to MTX instead MTX kindly sent a quotation for parts to be replaced, I can tell you what parts need to be replaced if you still need a solution.
Mtx ta7801 amp not working
Depending on where you live, Car Tunes is a good place to fix it but it might cost a good amount. I have a mtx 1501XD and the same problem, lights but no sound i saw no marks inside mine however. They told me i was better off buying a new one bc it was going to cost so much to fix most likely. That was coming from a guy I know so they were just trying to **** money out of me either, he does sound for a living.
Top MTX Car Audio & Video Experts
Jose Ramirez
Grand Canyon Tech
Grand Canyon Tech
Steve Sweetleaf
Steve Sweetleaf
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
