SOURCE: I keep getting error code pxe-m0f on my toshiba laptop model #c655d-s5200
Most likely your hard drive is dead. Go check with your local IT guy :)
SOURCE: toshiba c655d-s5133 plugged in not charging
Please check it out based on the following troubleshooting steps:
laptop plugged in not charging:
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. Make sure the DC jack is not loose or broken. A loose DC jack will need to be re-soldered. A broken one will need to be replaced.
4. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
5. The power button could be bad
6. The motherboard could be defective & needs to be replaced.
Replacement Toshiba Satellite C655D AC Adapter 75Watt 19V 3.95A
