The touch control panel isn't working for the cooker rings. They can be turned on but I can't increase the temperature setting. The oven and grill controls are working
SOURCE: AEG Oven
Probably there is an electrical relay that has failed.. or if electronically controlled, the equivalent circuitry. Or maybe a thermostat has failed. Be careful with anything electrical, as these kinds of faults may need a trained tradesperson. They can be dangerous to play with, as you need to be able to take electrical measurements and use tools to repair this yourself.
SOURCE: I have an AEG cooker but the marking around the cooker knobs have
Hi.
You need thermostat knob and main oven control knob.
SOURCE: how can i mend the grill and oven on my electric cooker?
If the rings work o/k then could be timer if it has one make sure it is set to manual and not auto.
Another thing it could be is a faulty selector switch, which selects the different functions.
Hope this helps.
Plz rate my solution.
Thanks.
SOURCE: Hotpoint BU62 double oven, no grill functioning
keep turning the oven/grill selector past the temperature settings, it feels like it won't go any further but it does!
SOURCE: I have an AEG D8800 4M oven. Oven overheating to
If it is a fan assisted oven, then make sure the fan is working o/k, if it is, then I would suspect that the oven thermostat is faulty and needs to be replaced.
