It gets warm aned then shuts off before it gets hot enough to steam
It was about 2 years between uses and i gotit out to use it worked roperty for a while and then it got to where it would get warm but would shut off before it got hot emough to creat steam
Is the coffee good? It's most likely the thermostat. Inside the thermostat sensor is stuck into a hole in the boiler; if it gets detached the thermostat won't work but the coffee machine will. Mine hasn't worked for years but the coffee still tastes fine.
I have this machine and have used it for about a year. Most important is use fresh beans within 15 days of roast, and within 15 minutes of grinding. You cannot get good results from this machine using pre ground coffee, or pods. Second, this machine is terrible with temperature stability. When warmed up it will usually be way too hot. Wait for the machine to warm up (light will come on). Open the steam valve, run the brew pump for 5 to 10 seconds into your cup and turn it off. Shut the steam valve, wait for the light to come back on. Immediately hit the brew button. This procedure will do a nice cooling flush and hit more towards the right temp.
Third, the pressurized basket that comes with this machine just dosen't do the job right. Replace it with a Mr. Coffee double basket, non pressurized and you will see immediately better results.
Last, the screeching steam wand. This machine will give wet steam, all the time. After pulling the shot, hit the steam switch and wait 20-30 seconds, then open the steam valve full to purge water out of the wand. Close the valve, then go to steaming your milk. There is a place about 1/4 inch below the surface that you'll hear only a chhh-chhh sound. Wand too deep, it will screech and wake the neighbors. Too shallow and you'll get sudsy big bubbles. Just find that sweet spot and surf there till you're at 140-150 degrees then turn the valve off. Good luck.
Hi When was the last time you descaled the machine? Scale will build up inside the boiler and insulate the water from the heating elements. The thermostat is on the outside by the heating elements so it gets hot but your water is warm. There are other things but check this first.
The magic delux has only one boiler so if you are getting hot water and steam, then it could be that the cup used to brew into is taking the heat from your espresso, trly warming up the cup before brewing into.
Try using the milk clamp on the tube going into the milk.Tightening it will make your milk hotter.
Your steam wand however, is a different problem.
First, check in the programming that the steam temp. is 125 celcius.
If it is, and none of the tubes from the steam wand to the boiler valve are blocked, your boiler temp. sensor may be faulty, in which case, you will need to replace that.
