In order to save data there are two options:-
1) When you reset the phone it will ask you whether you want to take backup of your SD card, check the option and the 2nd option will be erase everything from SD card, DO NOT CHECK THIS OPTION.
2) Go to applications and move all the apps to SD card, export all the contacts to SD card and after doing all these please remove the SD card and then reset your phone.
If the device has been reset once there is no option to retrieve the datas again.
Hard or master reset
A hard reset restores the original factory settings and may erase all downloaded content, including ringtones, images, programs, and contacts stored in the internal memory. To perform a hard reset, follow these steps:
Hard or master reset using hardware buttons
If the phone is locked, frozen, or unresponsive, you can hard reset it using the hardware keys instead of the menu. A hard reset restores the original factory settings and may erase all downloaded content, including ringtones, images, programs, and contacts stored in the internal memory. To perform a hard reset using hardware keys, follow these steps:
