PrintCopy .infohttps://printcopy.info > code=SC390
Code: SC390; Description: TD sensor error 1. The TD sensor outputs less than 0.5V, 20 s after the TD sensor initial setting has been performed.
Missing: cod ‎' Must include: cod
Fixyahttps://www.fixya.com > ... > Ricoh
The closest thing is the sc390 code, which means either the toner density sensor or the developer has gone bad, and typically replacing the PCU can fix that ...
Copytechnethttps://www.copytechnet.com > 56632-sc-390-a
Sep 24, 2011 - I've got an Aficio 1018 that's generating sc390 after every 10 copies. I recently fitted new drum, cleaning blade and developer and changed ...
Question edited to add the word Nintendo, because not everyone is a mind reader.
Question moved from Computers, to Nintendo now we know what a '3ds' is. Also fixed to '3DS'.
Make sure the printer is on and connected to the computer, either through your local network or a USB cable. Go to HP Customer Support - Software and Driver Downloads. If a Let's identify your product to get started page displays, click Printer, type your printer model number, and then click Submit. The software results page for your printer displays with the default operating system selected. If you need to change the version of Windows, click Change, select your version, and then click Change. Click Firmware, and then click Download. If a Firmware section is not listed, an update is not currently available for your printer. Save the file to your computer. Locate and then open the file to start the installation process.
Switch off
Open Toner Cover
Switch on, holding "System Menu"
Go to "Secure Setting"
"Enter"
Hold "Start" "#" "Enter"
Scoll down to "Maintenance Mode"
"Enter"
Scoll down to "U163"
Scoll do "Execute"
"Enter"
Close Toner Cover
Leave run for a few seconds
Switch off
Switch on....
Try to access the .jad directly by browsing to http://tether.com/t/tether.jad
I've found third-party sites hosting applications causing this error to occur on my 7100i
Sir, The system checked the COD files in the device for modification and determined that a problem exists with one or more COD files.If all loads fail, a build process error might occur (a problem exists with signing the COD files).If a user action on the device resulted in this problem, the reset cycle is continuous because the code in the filesystem has been corrupted. The only recovery method is to wipe the device and restore a new system.
Is this COD??
If so back up your gamesaves from COD to a meme stick.
Then put COD in and see what happens.
If it works then the game save was corrupt.
And yes you will have to start again.
