I cant get any channels with my coby tv
This COBY only has an analog tuner. Thus unless you are close to one of the remaining low-power stations, you need a digital-to-analog converter for OTA TV signals. For digital TV, you should use antennaweb.org or tvfool.com to identify the antenna and direction for the digital signals that you may be able to receive. Antennaweb assumes an outdoor antenna is conservative in the channel list it provides. Digital signal is either enough to register with the tuner or No Signal. An amplifier may be needed is the signal is split to several TVs.
If you have cable, check the type of signal coming in to the TV. If the signal has been switched to digital, you need a set top box.
I hope this helps.
