Map updates for navman N276
SOURCE: maps update
Navman is awful on support for map updates, which they claim are the latest. I've had mine less than a year and have decided to sell it and replace it with a Garmin. You can get maps that are 1-3 years old, even though Navman says 10 months old, for $149 USD. Horrible Company, it should be struck by lightning and let it burn to the ground!
SOURCE: navman maps , loading new maps through windows vista ??????????
I just had same problem while trying to load 2008 maps onto N40i . This I unfortunately discovered once I had already removed the existing maps as instructed part of install.
SmartST2006 isn't so smart! It kept saying I wasn't connected to internet when it was registering my product key' despite it most definitely being connected and I had temporarily disabled my AVG firewall just in case it was blocking.
I found an alternative way of registering the maps on the Navman website where it is required to enter the Navman serial number and the maps product key in order to get a code but that didn't work for me either, it didn't recognise my Navman serial despite having been fully registered when new.
My final (desperate) solution worked - find a computer with Win XP install SmartST2006 and hey presto! It took quite a while to load the maps though.
Proof to me that SmartST2006 is not compatible with Vista, if only they had put a slip in the maps box warning of this possibility.
The 'latest' pan Europe maps which are labeled 0408 actually appear to be 1106
SOURCE: GPS NAVMAN MODEL NO.N188 SERIAL
I am trying to find a Model No. for a Navman. I have the serial No.
SOURCE: Navman s30 3d 2009 map update is useless
You should be able to install your old map from the DVD/CD that originally came with your Navman - you don't need a Product Key for this, even if it prompts you for one.
It appears that the commercially available 2009 map for the S-Series does *not* cover the S30 3D, just the non-3D versions, although that's not at all obvious from what's on Navman's web-site, so you have my sympathies if you bought it expecting it to work...
SOURCE: I have a GPS Navman c40/c60 and want to update
The C40 is a "special" release for Australia, so I am presuming you are requesting information on Australian maps.
At present, the current map for Australia is 2009.
This link is for the Navman models you mentioned for Map information.
http://www.navmansupport.com.au/Maps/C%20Series.htm
Kind regards
