I sure would appreciate if anyone knows how to set the date and time on this model of calculator. Thanks in advance.
1. Switch the GT*RATE SET button to RATE SET.
2. Press the date/clock button to display current time.
3. Enter time wanted using military time. 4:52 p.m would be entered as 16.52 (Note the 16 is followed by . then enter the 52. (ie. 10:45 a.m. would be entered as 10.45)
4. Press the date/clock button again to enter new time.
Just reset mine and is current. If the built in battery needs changed, access panel is on the back. It uses a watch type battery.
~DLS
Finally set the time and date. I was all in using the (.) between the month, day, year. If thye date is June 10, 2011 then enter 06.10.2011 abd then the date/time set continure with setting the time as described above. Thanks for your posting DLS.
~RFR
Thank you very much. This was driving me crazy.
Exactly like Anonymous said. But if (error)message displays you need a new battery. (Under the calculator)
i want to print time and date onmy register tape
