SOURCE: My Maytag dishwasher does not drain water after the wash cycle is over
Hi olabrk,
If you have a disposal make sure it is clear. You can put some icecubes in it to clean the blades and run some water through to make sure the drain is clear. If the dishwasher will still not pump out all the water check the drain line from the dishwasher to the sink drain for obstructions. If the drain is you will have to check the pump for obstructions. Sometimes glass, popcorn, toothpicks etc.... can get in the pump and prevent it from pumping out. If the pump is clear, then you will need a new pump. Good luck to you.
Mike Anderson
SOURCE: We have a Maytag MDBH950AWS Dishwasher that won't start.
I have Miele incognito that when I shut the door it does not turn on? Not sure why it stopped working all the sudden
SOURCE: Maytag dishwasher.Loud humming noise, wash cyle,at beginning
Is the water filling up and then draining out? Mine did this and a part was broken inside the unit. The part was five dollars and called a lifter. I fixed it myself.
SOURCE: dishwasher doesnt drain on wash cycle,ok on rinse cycle
Change the circuit board, timer/progrsmer.
Take it out and clean contacts,
Look for burnt circuit line and solder a fine bead carefully on the circuit board, difficult. Use the pot and pan program.
Vitally
SOURCE: i have a Maytag MDB4651AWW3 dishwasher that stops during cycle
is it making a humming sound ,then the pump is blocked see if any thing is stuck under spray arm, worst could be is the motor unplug before working on it. thanks
Sorry to hear you are unhappy with the performance of your new Maytag dishwasher. Please take a look at this troubleshooting link and see if this helps http://bit.ly/ri57ll.
